U65GT_V2.0.2W_en_141231_mod Lepi
    Originally posted by Edius View Post
    For me worked in this way:
    1. installed 900supersport (september) ROM with 2,4 or 6 GB EBR1 andEBR2 and his custom CWM.
    2. instaled Lepi's TWRP (2.8.1.0 white) through 900supersport's CWM.
    3. installed Lepi's ROM (version is your choise) with all wipes from description (Dalvik Cache, Cache, System, Data, Android Secure)
    Lepi's ROM will not modify partition structure, unless you flash some .zip file (search in dedicated threads for that)
    My recommendation is to flash EBR1 and EBR2 before ROM flashing...that may cause instability and errors.
    exactly!
    None of the ROM I've seen so far installed from recovery can modify app partitions.
      Originally posted by mr..speed View Post
      Thanks Edius and all, will install TWRP later.
      You mean this TWRP_2810_light_LEPI.zip
      ui_print"- U65GT TWRP 2.8.1.0 mod_Lepi_new Theme"
      Here it is http://www.freaktab.com/showthread.p...l=1#post248978
      My advice is to go to sleep now and tomorrow morning after a good cup of tea(or beer ) re-read my previous posts, download all you need(900supersport ROM from Here , TWRP 2.8.1.0 from Here , Lepi's ROM (your choice on that...I'm pretty sure you'll find one) and reflash everything as I described.
      Regards, Edy.
        Since I have a Titanium Backup premium licence, I installed the TB.zip via CWM.
        Then I installed/tried the apps saved via TB to install via CWM, I saw on the screen instalation of my apps, than suddenly the Android screen came up, my cube was up and running.
        Starting TB, it says no root access !!!
        what's going on here ?
        To early for sleep
        could it be that the TB tried to install an other superuser, so I lost my roots ?
        Back to root, installed everything again and TWRP.
        Now I have to figure out how to bring back my apps backuped via TB
        Edy, the TWRP link is no more working: " removed by Lepi"or server problem, but I had already a copy of it.
          Lepi, thanks for the great ROM.
          The orange is a little bit hard to read in some conditions, like white backround.
          When I start Titanium Backup premium, go into cfg and open inside an option which shows a new menu, this menu is overlayed with the previous menu and I can not read it.
          Is this a TB or ROM problem ?
            When I start Titanium Backup premium, go into cfg and open inside an option which shows a new menu, this menu is overlayed this the previous menu and I can not read it.
            That's my fault. I'm working on it.
            videoTutor1 videoTutor2 videoTutor3 videoTutor4 videoTutor5 videoTutor6
            TWRP_2.8.1.0
            TWRP_2810_newTheme TWRP_2.8.5.0
            PayPal donate WMID410517421626
              Thanks for your investigation, looking forward for a fix.
              How do you restore your apps after installing a new ROM ?
              Can I restore my system data from the mfg 2.0 ROM since your base is this ROM.
                Thank you for BUGS, I have already corrected.
                Software I restored using Titanium.
                2.0 base system, of course you can.
                TWRP_2.8.1.0
                  Re flashed everything again a few times, restore of ALL the system data of mfg ROM V2.0 via TB at the end killed the tablet, reboot endless loop.
                  Maybe this helps others.
                  Any help about which system data not to restore is welcome.
                    Sorry, I'm not well understand English. I restore using Titanium only user software. I do not know what mfg.
                    TWRP_2.8.1.0
                      Hi Mr Speed....
                      Maybe this will help i also had the Boot loop Problem but only for a few minutes because after flashing again everything worked
                      If you dont want to flash over your PC again try enter factory reset mode use "wipe data factory reset" then use the "wipe cache partition" then install lepis v2.0.2 again over a microsd card in the factory reset mode.
                      NOTE: ALL YOUR DATA ON THE TAB WILL BE CGONE BY THIS PROCESS...
                      I DO NOT GIVE GUARANTEE FOR ANY DAMAGES
                      PS: dont restore try installing everything New in your tab.. This is much work but you will not have any problems again...hopefully
                      Best regards
                      Robert
                        On titanium Backup you MUST restore only: "restore MISSING apps + system data"
                        Often on new ROMs revision if you tap on "restore ALL apps + system data" will have result in endless loops!
                        It's not a matter of custom ROM! This is due to the fact that you are overwriting new system data (of the updated ROM) with older android data of your backup!
                          no touch screen !
                          I stupidly flashed this rom and didnt properly check my serial number, mine is earlier then the one recommended for this rom and I now i dont have any touch screen!, not sure what to do because i also dont have touch screen when I boot into TWRP recovery, Does someone please have any suggestions on a way of salvaging my tablet? Please help
                          EDIT : I tried reinstalling Supersports 1.8 rom from september, but when I boot to system I still dont have touchscreen, But I do have CWM installed now. Ive wiped the Dalvic, system/date reset, Wiped the cache but still no touchscreen, I thinking there must be a way of salvaging this, if anyone can help would be really apprecatiated thx )
                            Originally posted by Relles View Post
                            I stupidly flashed this rom and didnt properly check my serial number, mine is earlier then the one for this rom and I now i dont have any touch screen!, not sure what to do because i also dont have touch screen when I boot into TWRP recovery, Does someone please have any suggestions on a way of salvaging my tablet? Please help
                            Flash ROM provided here.
                            In my GDrive is an 1.8 who restore touch function
                              http://www.freaktab.com/showthread.p...l=1#post248665
                              Ahh ty so much !!, Will try it now
                                Ok I downloaded the file from your G drive, ty so much for that. But the problem Im having is when I try load the Bin File i get this error message : BROM ERROR : S_FTHND_FILE_LOAD_FAIL (5008).
                                I downloaded it again in case there was any errors but I still get the same error message above when I try to load the MTK Bin file, its driving me mad, Please help me !
                                Also i cant get the scatter file to load, it just says the file isnt legal or something?? Is there a way I can install it from CWM or something ?
                                Really frustrating because I know this rom will fix it
