U65GT_V2.0.2W_en_141231_mod Lepi
    Originally posted by simexi View Post
    Simple question, no answer
    Since this rom is pre-rooted, you can install one app, from many that are available in the play store, that can mount ntfs partitions. It's one click (tap) away....
      Works with serial number T9X201410180139 ...
      ... as printed on the backside of the body.
      My vote is for a back version, too.
      Thanks for your work!
        Originally posted by streumix View Post
        ... as printed on the backside of the body.My vote is for a back version, too.Thanks for your work!
        do you have a 32Gb version?
        If yes if you install this rom v.2.XX you may lose your touchscreen function!
          Actually it is a white 32GB model I received a few days ago. I just took the risk and gave it a try. And ... have been lucky. 2.0.2 is running fine. No trouble yet. And most important: Chrome and Feedly do work, which hadn't been the case with stock 1.8. And of course, root is essential, too.
            Works
            I have a 32gb black Version of the tablet and the 2.0.2w Version woks fine without any problems..
            The tab is bought in November
            Thanks lepi for your Grat work.. Already made a donatiin to you
              Thank you for your support. Today I am doing improvements light theme to white text does not lay on a white background. Already part of interface errors corrected. Hopefully soon all errors will be corrected.
              videoTutor1 videoTutor2 videoTutor3 videoTutor4 videoTutor5 videoTutor6
              TWRP_2.8.1.0
              TWRP_2810_newTheme TWRP_2.8.5.0
              PayPal donate WMID410517421626
                  Great i am looking forward for the next great release from you.
                    Hello Thanks to your great work.
                    I'm new to this and screwed up my 32GB cube.
                    I try to write what I did so far.
                    I started with mfg 2.0 ROM, got CWM installed.
                    I installed the 6GB fix via CWM, ok my Apps were gone.
                    I installed my TB back, build via TB as zip, than I wanted to reinstall my aps via TB and the saved aps via TB but I got an error package damaged or something like this.
                    Then I started to play, saw a gapps and installed this via cwm, not sure any more if I installed something else.
                    Now my Cube ended up in a boot loop.
                    What should I do now to get Lepi's costom Rom with 6GB installed.
                    Any help is wellcome
                      just install lepi's rom, you should have 6Gb of apps partition.
                        To clarify, if you want Lepi's ROM and 6 GB app storage you need to install Lepi's ROM first via TWRP and then flash 900ss EBRs over.
                          For me worked in this way:
                          1. installed 900supersport (september) ROM with 2,4 or 6 GB EBR1 andEBR2 and his custom CWM.
                          2. instaled Lepi's TWRP (2.8.1.0 white) through 900supersport's CWM.
                          3. installed Lepi's ROM (version is your choise) with all wipes from description (Dalvik Cache, Cache, System, Data, Android Secure)
                          Lepi's ROM will not modify partition structure, unless you flash some .zip file (search in dedicated threads for that)
                          My recommendation is to flash EBR1 and EBR2 before ROM flashing...that may cause instability and errors.
                            The first boot lasts a long time, you need to wait patiently and not to touch the display.
                            I installed the 2.0.2 via CWM and rebooted.
                            But my wife touched the screen by accident, I'm getting "Loading System" for over 1 hour now.
                            Is it broken ?
                            should I Repower ?
                            reinstall ?
                            or still wait ?
                            Could it be that I forgot a wipe, what about then, same procedure again ?
                            The wipe options are different in CWM.
                              Is it broken ?
                              should I Repower ?
                              reinstall ?
                              or still wait ?
                              1 hours is way too much.
                              If you'll power off, I'm 100% positive you tablet will no longer boot on android.
                              If you will power off, maybe (and is more than positive) your recovery is working and you can start a new flashing process.
                              My advice is to power off (keep power button pressed for ~ 10 seconds) boot into recovery and flash Lepi's TWRP from an external SD card (through 900supersport CWM - I hope this is flashed at this moment)
                              After that do all wipes and reflash Lepi's ROM.
                                OK,
                                saw your post to late one more
                                rebooted into CWM recovery
                                wipping cache
                                wipping data ==> says: data, cache, /sdcard/.android_secure
                                installing 2.0.2 update
                                reboot system now
                                hey, asks for launcher :-)
                                system up and running
                                that was quick maybe 3 minutes
                                Thanks Edius and all, will install TWRP later.
                                You mean this TWRP_2810_light_LEPI.zip
                                ui_print"- U65GT TWRP 2.8.1.0 mod_Lepi_new Theme"
