[ROM] HOMLET V1 (20.01.2015) - based on CX-A99-A80-4.4-6335-20141219v1.img
    HOMLET V1
    Leider konnte Ihre hochgeladene Datei nicht gefunden werden. Laden Sie die Datei neu hoch.
    USE THE BUTTON
    THIS IMG IS NOT SUITABLE FOR "STARTUP MODE"
    PHOENIXCARD CRASHES WHEN USING THIS MODE
    FIX:
    Use imgRePacker_205 :
    1) drag, "draco_aw80_dovless_1.09.img" on "imgRePacker.exe".
    2) delete ROM draco_aw80_dovless_1.09.img.
    3) drop your folder "draco_aw80_dovless_1.09.img.dump" on "imgRePacker.exe".
    * feel free to mirror anywhere
    * license: Attribution + Noncommercial + ShareAlike
    NOTES & DISCLAIMER:
    * This ROM was made for testing and educational purposes.
    * It is not intended for commercial use.
    * Software included may be subject to copyright.
    * Flash this ROM at your own risk. Developer is not responsible for what you do on your device.
    1) For taking advantage of some of the features added to this ROM you will need a USB key.
    All my tests are performed on:
    Maxone CX-X8 4GB/32GB model
    http://www.geekbuying.com/item/Maxon...0M-339872.html
    A ROM modification based on:
    "Stock firmware" Tronsmart:
    version 1 of 12/19/2014 a.k.a. :
    HOMLET V1 - A rom with modifications similar to dovless 1.09
    DOVLESS-0.01 ROM : Information and features ==> retired:
    replaced by HOMLET
    DOVLESS - 0.01
    Last edited by GJayJayG; 20 January 2015, 22:55. Reason: HOMLET V1 - added DL link
    hi GJayJayG, thank you for your ROM, I just downloaded and installed.
    - Rom, seems much more reactive.
    - (MXPlayer) there is no longer the problem, little line in the video, it's ok as Original ROM.
    - In streaming movies with the Firefox browser, there is no longer the problem, little line in the video, it's ok as Original ROM.
    - I read a 720p video with kodi 14 final, and after 8 minutes, the video stop in, pause.
    it may be just kodi.
    For me this is an excellent result for your work and that of finless,
    There are always, little problem with video playback (stutters) when the camera moves,
    but it is the fault of the original firmware, new firmware soon to come (January 15), hope to repair the video problem.
    Just 2 questions :
    1) why the ROM (draco_aw80_dovless_0.01) fact 470 Mo ?
    draco_aw80_finless_rom_1_0 is 528 Mo.
    2) it will not be installed your ROM, in the external SD card (for faster test)?
      Just 2 questions :
      Thank you for the feedback,
      I'm glad that the fixes you were looking for are working.
      Regarding the size difference, I would say that the base rom are different , difference in APK packaged may be partly responsible for it.
      Using dragonface you can open up any A80 rom and check exactly what is included.
        [REQUESTED]full build.prop of 0.01 - THX TO 4PDA.RU FORUM & particularly: buhsoft2006
        Code:
        # begin build properties
        # autogenerated by buildinfo.sh
        ro.build.id=KOT49H
        ro.build.display.id=Finless 1.0 4.4.2 KOT49H 20141114 release-keys
        ro.build.version.incremental=20141114
        ro.build.version.sdk=19
        ro.build.version.codename=REL
        ro.build.version.release=4.4.2
        ro.build.date=Fri Nov 14 11:32:00 PDT 2014
        ro.build.date.utc=1414142167
        ro.build.type=release
        ro.build.user=finless
        ro.build.host=finless-desktop
        ro.build.tags=release-keys
        ro.product.model=Nexus 10
        ro.product.brand=google
        ro.product.name=mantaray
        ro.product.device=manta
        ro.product.board=manta
        ro.product.cpu.abi=armeabi-v7a
        ro.product.cpu.abi2=armeabi
        ro.product.manufacturer=samsung
        ro.product.locale.language=en
        ro.product.locale.region=US
        ro.wifi.channels=
        ro.board.platform=jaws
        # ro.build.product is obsolete; use ro.product.device
        ro.build.product=jaws-tvd-p1
        # Do not try to parse ro.build.description or .fingerprint
        ro.build.description=finless 4.4.2 KOT49H 20141114 release-keys
        ro.build.fingerprint=Tronsmart/finless/finless:4.4.2/KOT49H/20141114:eng/release-keys
        ro.build.characteristics=tablet
        # end build properties
        # ADDITIONAL_BUILD_PROPERTIES
        ro.com.android.dateformat=MM-dd-yyyy
        ro.config.ringtone=Ring_Synth_04.ogg
        ro.config.notification_sound=pixiedust.ogg
        ro.config.alarm_alert=Alarm_Classic.ogg
        drm.service.enabled=true
        wifi.interface=wlan0
        #wifi.supplicant_scan_interval=15
        wifi.supplicant_scan_interval=150
        keyguard.no_require_sim=true
        ro.sys.network_location=true
        af.resampler.quality=4
        audio.output.active=AUDIO_CODEC,AUDIO_HDMI
        audio.input.active=AUDIO_CODEC
        ro.sf.showhdmisettings=7
        dev.disp_type=4
        dev.disp_mode=10
        ro.kernel.android.checkjni=0
        #ro.sw.testapkpackage=com.softwinner.dragonbox
        #ro.sw.testapkclass=com.softwinner.dragonbox.Main
        #ro.sw.testapkconfigclass=com.softwinner.dragonbox.Configuration
        #ro.sw.agingtestpackage=com.softwinner.agingdragonbox
        #ro.sw.agingtestclass=com.softwinner.agingdragonbox.Main
        #ro.sw.snwritepackage=com.allwinnertech.dragonsn
        #ro.sw.snwriteclass=com.allwinnertech.dragonsn.DragonSNActivity
        ro.opengles.version=196608
        persist.sys.strictmode.visual=0
        persist.sys.strictmode.disable=1
        debug.hwc.showfps=0
        persist.sf.showhdmisettings=7
        persist.sys.hdmimode=10
        persist.sys.hwc_p2p=0
        #persist.sys.disp_density=160
        persist.sys.disp_density=240
        ro.sys.adaptive_memory=0
        dalvik.vm.heapsize=512m
        dalvik.vm.heapstartsize=16m
        dalvik.vm.heapgrowthlimit=384m
        dalvik.vm.heaptargetutilization=0.75
        dalvik.vm.heapminfree=2m
        dalvik.vm.heapmaxfree=8m
        ro.zygote.disable_gl_preload=true
        persist.sys.usb.config=mtp,adb
        #persist.sys.usb.config=mass_storage,adb
        ro.udisk.lable=CX_A99
        ro.adb.secure=0
        ro.property.tabletUI=false
        ro.property.fontScale=1.0
        ro.sf.hwrotation=0
        debug.hwui.render_dirty_regions=false
        ro.property.max_video_height=2160
        ro.setupwizard.mode=DISABLED
        ro.sys.cputype=UltraOcta-A80
        persist.evb_flag=1
        #BUILDPROP EDITS ==> [B]thx to buhsoft2006 @ 4PDA.RU[/B]
        ro.hwui.texture_cache_size=60
        ro.hwui.layer_cache_size=48
        ro.hwui.path_cache_size=12
        ro.hwui.shap_cache_size=3
        ro.hwui.drop_shadow_cache_size=6
        ro.hwui.r_buffer_cache_size=6
        #ro.product.firmware=homlet4.4.2-a80-v2.0rc3
        ro.product.firmware=dovless.1.0-4.4.2
        ro.product.rom.type=YB
        ro.product.rom.name=BoxRom
        ro.softmouse.left.code=71
        ro.softmouse.right.code=21
        ro.softmouse.top.code=70
        ro.softmouse.bottom.code=22
        ro.softmouse.leftbtn.code=85
        ro.softmouse.midbtn.code=-1
        ro.softmouse.rightbtn.code=-1
        ro.carrier=wifi-only
        persist.sys.timezone=America/Los_Angeles
        #persist.sys.country=US
        #persist.sys.language=en
        persist.sys.device_name=Draco_AW80
        ro.com.google.gmsversion=4.4
        persist.sys.dalvik.vm.lib=libdvm.so
        dalvik.vm.dexopt-flags=m=y
        net.bt.name=Android
        dalvik.vm.stack-trace-file=/data/anr/traces.txt
        # begin DOV BUILDPROP EDITS ==> [B]thx to buhsoft2006 @ 4PDA.RU[/B]
        debug.sf.nobootanimation=1
        qemu.hw.mainkeys = 1
        dalvik.vm.execution-mode=int:jit
        dalvik.vm.verify-bytecode=false
        dalvik.vm.lockprof.threshold=500
        ro.kernel.checkjni=0
        windowsmgr.max_events_per_sec=60
        video.accelerate.hw=1
        debug.performance.tuning=1
        debug.sf.hw=1
        debug.egl.hw=1
        debug.egl.profiler=1
        debug.composition.type=gpu
        persist.sys.ui.hw=1
        hw3d.force=1
        hw2d.force=1
        force_hw_ui=true
        media.stagefright.enable-meta=true
        media.stagefright.enable-player=true
        media.stagefright.enable-scan=true
        media.stagefright.enable-http=true
        media.stagefright.enable-record=true
        media.stagefright.enable-rtsp=true
        net.rmnet0.dns1=8.8.8.8
        net.rmnet0.dns2=8.8.4.4
        net.dns1=8.8.8.8
        net.dns2=8.8.4.4
        net.tcp.buffersize.default=524288,1048576,2097152,262144,524288,1048576
        net.tcp.buffersize.wifi=524288,1048576,2097152,262144,524288,1048576
        # end DOV BUILDPROP EDITS ==> [B]thx to buhsoft2006 @ 4PDA.RU[/B]
        # begin fota properties
        ro.fota.platform=AW_A80_KK
        ro.fota.type=box
        ro.fota.oem=sunchipA80_KK
        ro.fota.device=Draco AW80
        ro.fota.version=jaws_tvd_p1-eng 4.4.2 KOT49H 20141024 test-keys
        # end fota properties
          Originally posted by GJayJayG View Post
          http://4pda.ru/forum/index.php?showt...ost&p=37189900
          # new video settings
          ro.hwui.shapE_cache_size=3
          ok, apparently an E was missing from "shape"
          Source:
          & some user are reporting stability issues with these lines:
          Code:
          [LEFT][COLOR=#465584][FONT=Verdana]
          dalvik.vm.verify-bytecode = false [/FONT][/COLOR]
          [COLOR=#465584][FONT=Verdana]dalvik.vm.lockprof.threshold = 500
          [/FONT][/COLOR][/LEFT]
          Credit to buhsoft2006 & Y5E from 4PDA.ru for these findings
            great work. thank you. Box feels snappier.boot up speed is amazing
              Is there any chance for this rom to be updated and supported like the dovless 1.08 one?
              I ask because the 1.08 doesnt work with amazon instant video on my draco.
              I think something is different in the basic fantasy rom. The amazon does even start, but when I try to play a video, nothing happens and Im back on the startup screen of the amazon app.
              Thanks and best regards
              I hope you have fun with my english writing!
              Now Draco Meta...coming from Vega S89-H, wdtvhd 1, xtreamer 1, zotac ion, raspi and some android smartphone skills
                I'll update this one as soon as the various tweaks are all confirmed, so that I that I don't make intermediary builds. I'm also open to changing the base ROM, if a consensus is reached on what is THE best rom to work with.
                Lastly, we all benefit from user testing, peer reviews and feedback.
                Since we have to work with iterations to get where we want, if we all contribute to the effort, the desirable state will be reached sooner.
                The below image to show that I'm trying to do my part and I'm not hesitant to test various images.
Name:	2015-01-19 20_12_39-002_ORIGINALROMS.png
                  Hi GJayJayG, I tested your ROM Homlet V1 (01/20/2015)
                  All the ROMS works with external sd card to boot,
                  by against, "Homlet V1 (01/20/2015)" burning ok, but block on logo tronsmart.
                  ROM Homlet V1 (01/20/2015), has the same problem with the draco tronsmart (for me) with the exotic ROMS:
                  - Arctefact in the video, with MX player
                  - Arctefact in the video, with some players in the web browser (Daylimotion)
                  - With Kodi 14.15 ... the video stutters a bit
                  I did the test, if you wanted to know.
                    Dear Moulin1980,
                    Thank you for the feedback and for your tests, I guess this will be the one an only version using this ROM as a base.
                    Still on the hunt for the good base image, feel free to share your opinion and experience on this as well.
                      CX-A99-A80-4.4-6335-20141219v1.img is my best ROM and the one that I have now for using
                      I hope this ROM will take it to a higher level
                      So I have to delete my primary ROM (CX-A99-A80-4.4-6335-20141219v1) to test this, and do a normal flashing method which I do not like it.
                      I hope if it is working from SD Card later
                        Actually, you do not, Moulin has found a way to fix my crap images for "startup mode"
                          http://www.freaktab.com/showthread.p...l=1#post273578
                          Thank you, but it is too late, I did a normal flashing
                          First note is this ROM did not auto adjust screen size like the original
                          antutu benchmark is 36987
                            It is Not working for me with both ROMs, dovless or homlet
                              Just testing Homlet V1 (burning)
                              I found as is the image will burn as a Product and not as Startup
                              If you run it thru imgRePacker_205 is will burn as a Startup but not as a Product.
                              How Bizarre.
                              Cheers
