[ROM] HOMLET V1 (20.01.2015) - based on CX-A99-A80-4.4-6335-20141219v1.img
    How to backup/restore your rom.
    http://www.freaktab.com/showthread.php?19891-NEW-TWRP-Recovery-for-Tronsmart-Draco
    sd card flashing method
    i will put a link to kodi 14.0.alpha3 later.
    Originally posted by Catadarius View Post
    Thanks for the info,
    But....where i can find the 14.0 alpha 3 ?
    Can you tell me also how can i flash with sd card.
    I appreciate the patience.
      Download kodi 14.0.alpha3 by this link
      MEGA provides free cloud storage with convenient and powerful always-on privacy. Claim your free 50GB now!
        60 FPS Playback?
        Hello! I first have to say that im a fan of the Soap Opera Effect (Motion Interpolation) for my videos. My sharp tv does a nice job of doing that at 120hz. My question is if the Draco Meta can play a 60 FPS files? I dont have any 60 FPS files and i understand that they can take up alot of space some times due to the amount of data/frames. Ive seen some other posts here of pictures of big buck bunny which i know is 60 FPS but i dont know how to tell if the Draco is actually playing it at 60 FPS. Is there a best/recommended player for this or is the Draco Meta even capable of playing these type of files? Im currently on the Homlet ROM using MX Player and TVMC for my video players with No Frills CPU on.
          Originally posted by thegergz View Post
          Danm, anyone know a way to fix this?
          Why yes I do know how to fix this, get the app (hide system bar)https://play.google.com/store/apps/d...eamori.hidebar
          Open it and hide bar boom done!
          Its a workaround but it works
            I would love to find a way to auto his system bar in Netflix or apps I select so if someone knows of a app that disables system bar on a per app basis it would be great! Let me know.
              Excellent find, Thanks
              Now I can use Netflix controls
              Works well for the Netflix problem in draco
              Causes other minor issues with screen navigation, resize and moving widgets,
              but as you say a workaround.
              Cheers
                https://mega.co.nz/#!xZpnwaBa!vf64iG...ogMsRfZAKPinQY
                Thank you
                Kodi works well now.
                  Cheers
                  agree turn on for netflix off after
                    Originally posted by GJayJayG View Post
                    HOMLET V1
                    Leider konnte Ihre hochgeladene Datei nicht gefunden werden. Laden Sie die Datei neu hoch.
                    USE THE BUTTON
                    THIS IMG IS NOT SUITABLE FOR "STARTUP MODE"
                    PHOENIXCARD CRASHES WHEN USING THIS MODE
                    FIX:
                    * feel free to mirror anywhere
                    * license: Attribution + Noncommercial + ShareAlike
                    NOTES & DISCLAIMER:
                    * This ROM was made for testing and educational purposes.
                    * It is not intended for commercial use.
                    * Software included may be subject to copyright.
                    * Flash this ROM at your own risk. Developer is not responsible for what you do on your device.
                    1) For taking advantage of some of the features added to this ROM you will need a USB key.
                    All my tests are performed on:
                    Maxone CX-X8 4GB/32GB model
                    http://www.geekbuying.com/item/Maxon...0M-339872.html
                    A ROM modification based on:
                    "Stock firmware" Tronsmart:
                    version 1 of 12/19/2014 a.k.a. :
                    HOMLET V1 - A rom with modifications similar to dovless 1.09
                    DOVLESS-0.01 ROM : Information and features ==> retired:
                    replaced by HOMLET
                    DOVLESS - 0.01
                    Anybody has this up on other source ? ,I can’t download it I get 4 warnings from my antivirus ,much appreciate it
                      could you just ignore the warning and keep on downloading ?
                        Whenever I did that I did got infected ,I rather not ,i did try but than i get some exe file so obviously fishy I know sometimes antivirus can recognize programs as virus but this is not the case always that exe file wants to download not the img. ,that’s alright I guess I am stuck with A80-4.4-6335-20150108_v2.img until a good official release .
                          There're 2 download buttons, click the one on the right.
                            That is the one i clicked on i tried it again same exe extension and a bunch of adware wants to pop up and surveys being blocked by my antivirus definitely something isn’t right .
                              Hit the button shown on the image.
                                That what i am doing (Windows 8.1 and 7 ) i also tried on my android and there was downloading some game instead the img file ,forget it thanks for the efforts though !
