watch your inbox in one hour...
[ROM] HOMLET V1 (20.01.2015) - based on CX-A99-A80-4.4-6335-20141219v1.img
Originally posted by frhdt007 View PostHi GJayJayG,
1) easily flashed with SD card !
2) set screen percentage to 90% to avoid horizontal lines (no problem there)
3) kodi 14.1 not smooth I have to install 14.0.alpha3 from Tronsmart rom.
Everything that works under 20141219v1 rom is still there.
One obvious gain for me:
The cbc player on cbc.ca works better in chrome . Under 20141219v1, it starts with HD for 9 seconds and goes back to 320p. Under your rom, it stays at HD resolution but it runs only 3 minutes 40 seconds , then stops. That happens with stock browser, chrome, opera, dolphin,... I see there's still a lot of video in buffer on control bar. Any idea ?
Thanks for sharing your hard work !
Curious - have you tried the kodi v15 nightly build? I am running with finless rom and by happenstance downloaded and tried kodi v15 and BOOM! Worked well. No stutter, no stupid blurred line at bottom, no frame skipping - I used a 4gig 1080p aac 5.1 file played via samba share from my networked rk3188 stick. Played smooth as silk. FF and rew even did ok..
Originally posted by spideymon View PostCurious - have you tried the kodi v15 nightly build? I am running with finless rom and by happenstance downloaded and tried kodi v15 and BOOM! Worked well. No stutter, no stupid blurred line at bottom, no frame skipping - I used a 4gig 1080p aac 5.1 file played via samba share from my networked rk3188 stick. Played smooth as silk. FF and rew even did ok..
RK3288 Devices
- Overview BOX (LINK !)
There are currently 1638 users online. 0 members and 1638 guests.
