Amazon prime video works great now. I haven't had any random power off notifications. Im testing video playback now and it seems much better than doveless. Until allwinner comes up with a new base rom in my opinion this is the rom that should be tweaked with. Doveless is very close but not 100% compatible with the draco like Eric was saying.
[ROM] HOMLET V1 (20.01.2015) - based on CX-A99-A80-4.4-6335-20141219v1.img
fixed a ton of stuff
Hello guys
Anyone know if the same old hardware usb keyboard problem persists?
How about not coming out of standby, is that still an issue?
Until Lollipop, those are the two major issues I would change roms for...
Thanks,
Mark._________________________________________
Out: USB audio, HDMI
In: Logitech K400 keyboards
See the pics at conclusion
RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View PostSee the pics at conclusion
http://www.freaktab.com/showthread.p...l=1#post259107
Thanks for the comprehensive reply - very interesting test results.
Originally posted by Zahir View PostIs anyone seeing more than a single CPU core enabled (under System Info in XBMC running the Eminence skin)?
Maybe the others are activated on-demand...
This fact contrast with the info provided with the same method on RK3188 (Minix Neo X7) and RK3288 (Beelink R-89) where the entire 4 cores of the SoC can be seen working at the same time; using interactive or Performance governor the 4 cores are shown working.
Same happens with the total RAM shown, whilst in Rockchip devices the total 2Gb Ram are shown (2048 Mb) in Draco AW80 Meta only 1624 Mb is recognized and in Telos 3146 Mb; this situation had not been explained yet by Tronsmart / Allwinner.Last edited by BTR11; 30 January 2015, 08:41.
Originally posted by thegergz View Postis this rom effected by the bugged out nextflix menu bar
Cheers
external keyboard and standby issues
Hello guys
I found that the external usb wireless keyboard stops working (key entry) after a short while - same as all ROMs on this box...((
I still have to see if the drako can be awoken from standby mode.
Mark.Last edited by fredphoesh; 05 February 2015, 13:59._________________________________________
Hi GJayJayG,
1) easily flashed with SD card !
2) set screen percentage to 90% to avoid horizontal lines (no problem there)
3) kodi 14.1 not smooth I have to install 14.0.alpha3 from Tronsmart rom.
Everything that works under 20141219v1 rom is still there.
One obvious gain for me:
The cbc player on cbc.ca works better in chrome . Under 20141219v1, it starts with HD for 9 seconds and goes back to 320p. Under your rom, it stays at HD resolution but it runs only 3 minutes 40 seconds , then stops. That happens with stock browser, chrome, opera, dolphin,... I see there's still a lot of video in buffer on control bar. Any idea ?
Thanks for sharing your hard work !Last edited by frhdt007; 05 February 2015, 17:11.
Hy guys,
After i received my draco, i only flashed finless 1.1 beta2, with phoenix software.
If i want to flash this, what are the steps that i can do....i mean, it's ok if i flash this with phoenix software?
And another question....there is an xbmc/kodi version that works better than other. At the moment i have spmc beta2, but is crashing when i stop an playback.
xbmc 14.1 does not work well with this rom. I had to install 14.0.alpha3 from Tronsmart rom.
Originally posted by frhdt007 View PostYour flashing method should work. I prefer sd card method.
But....where i can find the 14.0 alpha 3 ?
Can you tell me also how can i flash with sd card.
I appreciate the patience.
There are currently 4111 users online. 3 members and 4108 guests.
