I took away the cooling film, put 5 small heatsinks (15x15x15 mm) over the cpu and the power supply.
Backside of the mainboard I put a cooling pad over the complete surface of the board (5 mm thickness), so that there is a contact to the aluminium case.
The temeratures are about 30 degrees celsius. After 10 minutes prime with 100 percent cpu usage I have temeratures about 50 degrees on all four cores.
There is no need of air cooling at all. That´s it,
greetings and good luck for you guys.
