Copper is a significantly better heat conductor than aluminium, so this is probably incorrect.
Heatsink modding
Originally posted by TerryH View PostCopper is a significantly better heat conductor than aluminium, so this is probably incorrect.
Originally posted by robmich View PostWithout mods, I average between 53c and 72c. I have not experienced any obvious throttling of the CPU.
Rob
So how do these three items look?
http://www.****.com/itm/1pcs-100mm-0...item3a9ca056bb
http://www.****.com/itm/5pcs-30x30x1...item2ec0bc8312
Also, do you use the thermal adhesive to mount the pad as well, or is that just for the heatsinks?
Thanks for your help guys I have never done anything liket his before, but it seems like a wise thing to do and not too tricky.
If someone wanted to write up a more step by step instruction, that would be great as well.
Originally posted by portezbie View PostI think he means because the 15mm heatsink allows it to touch the case so the heat can transfer to the metal body of the case. But you are probably right that 15mm copper heatsinks might be even better.
Originally posted by portezbie View PostI'm curious, has anyone tested the temps without modding? What kind of temps does this get without modding?
Edit: Nvm, I found it.RK3288 Devices
- Overview BOX (LINK !)
RK3288 Devices
Originally posted by kotobide View PostThat metal plate with the holes in it that you have the heat sinks on is that stock that came with the box or is that something you added?
Originally posted by no_spam_for_me View PostIf I'm not wrong someone contacted this seller and got the answer that these pads only have 1 - 1.5 W/mK and that's not really good...
http://www.tomshardware.co.uk/forum/...e-higher-worse
http://www.amazon.com/Arctic-Alumina...ermal+adhesive
And can you or anyone recommend a better thermal pad?
Here they talk about > 9,0 W/mK
But if I'm you, I would try to find a pad with >= 5 W/mK, adhesive on both sides and e.g. 0.5mm, so you can replace the heat sinks...
Also try to find one with good W/mK and adhesive at only one side (I don't know which mm you need) to replace the one under the metal plate over the CPU...RK3288 Devices
What about these? I would recommend probably the thinnest one.
100mm x 100mm x 0.15mm ; 0.30mm ; 0.50mm ; 1.00mm ; 2.00mm ; 3.00mm ; 4.00mm ; 5.00mm
http://stores.****.co.uk/andyscomput...ape+Conductive
Or these? The blue ones have better thermal conductivity than the black ones.
http://stores.****.co.uk/thegameboot...+ADHESIVE+TAPE
There are currently 1688 users online. 1 members and 1687 guests.
