Heatsink modding
I have just opened my Pipo X7 and found that there is something stuck on the CPU / RAM shielding.
I looks like a black metallic sheet, but there is a plastic sheet between it and the shielding.
Someone knows what it? I didn't see it on any pics posted on this thread?!!
Should I remove the plastic sheet? It does not seem good for heat transfer...
Heatsink modding
I have done a temporary mod to the pipo while awaiting thermal adhesive and pad. I placed a single 25x25x15 mil heat sink on top of cpu's metal plate and secured it by reassembling the box. The screws on the motherboard hold it securely to the heatsink when tightened. The Heat sink is on top and touches the the aluminum box when secured by reassembly. I then placed an approximately 40x40x5 mil thermal pad on bottom like Scooby-Doo. With 1, 15 mil high heat sink, the motherboard doesn't seem to bend, although it is tight which is a necessity with my mod. My box is now running at 41 Celsius at startup as compared to 50 Celsius before mod. On my machine Screensaver was running at 79 Celsius vs 56 Celsius now. My question is what should normal temperatures be? Do I need to lower the temperature more?
Originally posted by CRi View PostI have just opened my Pipo X7 and found that there is something stuck on the CPU / RAM shielding.
Originally posted by smokie171 View PostI have done a temporary mod to the pipo while awaiting thermal adhesive and pad. I placed a single 25x25x15 mil heat sink on top of cpu's metal plate and secured it by reassembling the box. The screws on the motherboard hold it securely to the heatsink when tightened. The Heat sink is on top and touches the the aluminum box when secured by reassembly. I then placed an approximately 40x40x5 mil thermal pad on bottom like Scooby-Doo. With 1, 15 mil high heat sink, the motherboard doesn't seem to bend, although it is tight which is a necessity with my mod. My box is now running at 41 Celsius at startup as compared to 50 Celsius before mod. On my machine Screensaver was running at 79 Celsius vs 56 Celsius now. My question is what should normal temperatures be? Do I need to lower the temperature more?
There are some tiny holes on the metal plate, so you cannot use Arctic Silver 5, because it may enter the holes and short some circuits underneath. The chances of this happening are close to zero, but better be on the safe side.
Make sure that the heat sink cannot slip out of its place, because it will short some circuits and fry your device.
Originally posted by Pelliculart View PostHi guys (and ladies),
i'm happy to say i've resolved all my temperatures trouble with your kind advices. A special thank's to ScoobyDoo ^^
No more talk, just pictures :
And the CPU temperature and now 45 degrees when they were at 85 degrees in the same time.
And after 4 hours of stress, the CPU never go up to 70 degrees, excellent !
Used only 3 tools :
One thermal pad : http://www.amazon.fr/gp/product/B0051C287K
thermal adhesive : http://www.amazon.fr/gp/product/B006WXOV7W
heatskins : http://www.amazon.fr/gp/product/B008LZO3NQ
Originally posted by smokie171 View PostDo I need to remove plastic over metal plate, I am using a heat sink placed on top of plastic currently. I do not yet have thermal adhesive pads. How do I remove metal plate to place thermal adhesive pad on cpu. Do I just pry it off carefully?
Beware! You do not have to use adhesive pads! There are at least two reasons to avoid using adhesive pads, the first one being that you will not be able to remove the metal plate easily, and the second one being that adhesive pads are less efficient than regular pads.
Originally posted by kgian76 View PostSo, you used 1mm thermal pad for the underside of the mainboard. Does it make contact with tye bottom plate, because everyone seems to suggest that 5mm is needed...
There is no contact, but it seem like 2, 3 degrees better than nothing, with my 1mm.
But maybe you are right i'll be quite better with 5mm.
I hear any idea if someone had try 1mm and 5mm, and a suggestion of 5mm pad that I can buy (on amazon for exemple).
heatsink
Just posted this in a different thread - I had some spare heatsinks left over from a modified graphics card cooler, stuck them on with thermal glue and get 63oC (use CPU burn). Just peel back the film and stick on with thermal grease. Could get better with a little more effort but that temp is well within spec.
There are currently 3110 users online. 4 members and 3106 guests.
