Heatsink modding
Originally posted by jake123 View PostThe 5mm pad that Vinchenzo ordered is probably 1.2W/mK type. Would that be sufficient? Is that what you used? Thanks.
yes you are right,
that was the seller sent to me when I ask about specification,
https://drive.google.com/file/d/0B-MAfsHqjcjhSnFjOGhSNk1GZTA/view?usp=sharing
Photography and pictures of places, animals, nature, underwater, travel, and more. Turn Your Photo Into an Original Piece of Art Free. Photo Contest. Over $100,000.00 in prizes. Rate My Photo Contest ... Turn Your Photo Into an Original Piece of Art
.....so will going to trash,my badLast edited by Vinchenzo; 09 March 2015, 19:53.
After searching a lot for some decent thermal pads, and finding some candidates, I realized that I ended up in the same choice that most other users have already made.
These stores belong to the same company:
Xbox-experts.com
Thermal-pads.com
X-EX.com Shop store on ****
http://stores.****.com/xboxexpertsco...nkw=ThermalPad
This is a 5W/mK product:
[EC-360™ BLUE] 5MM 100x100 Thermalpad 5W/mK
http://www.****.com/itm/EC-360-BLUE-...-/111341822880
This is a little bit cheaper 2.5W/mK product:
[EC-360™ GREEN] 5MM 100x100 Thermalpad 2.5W/mK
http://www.****.com/itm/EC-360-GREEN...-/121300307570
These are very expensive, but the smaller and thicker ones can be used on the chips:
Fujipoly / ModRight Extreme Thermal Pads
Fujipoly / ModRight Ultra Extreme Thermal Pads
I had the same issu like you do, same board 1.3
I put this on Thermal pad XT 1mm, 7W/mk (120x20mm) Phobya
http://www.****.co.uk/itm/Phobya-The...-/331498394896
Now I have 52 C at full load for 30min
Originally posted by scropion86 View Postmine is reaching 82 C just for playing a 720P Movie for half hour , i stopped using it till i got my hands on
small heatsink and thermal conductive pads to modify it , otherwise my CPU will fried .
it seams that the board V1.3 have more heat problems than V1.2
Originally posted by strix View PostI had the same issu like you do, same board 1.3
good ,but my problem i can't get any thermal pads here at all , so laptop fan is alternative
and after long searching in computer repair shops i got my hand on these
i will try to play with it today to see the results
the silver aluminum heatsink is 30x30x10 MM
the golden on is 30x30x6 Mm
the fan is 5V 0.32 mA and height is 12 MM
and i will use a normal thermal paste and i till stick it to the board using a hot glue Gun
same with the fan
i found only very thin double tape but not thermal , i don't know if i used it maybe prevents heat to transfer from aluminum plate to heatsink , any idea??
Hi everyone,
it's there anyone who already order this thermal pad
http://www.****.com/itm/EC-360-BLUE-...68&mfe=sidebar
and like me will not use more then 30mm*50mm
Scooby-Doo post 126,
and it's agree to sell what are it's left from the thermal pad!
Don't understand me wrong I just want save money,
because I'm pretty sure there is no one here,who are thinking,
will have to mod his box and gave maybe 1/2 from the real price of the box!
I hope you understand me what I wanted to tell,because my English it's very bad!
Thank youLast edited by Vinchenzo; 10 March 2015, 10:11.
Originally posted by scropion86 View Postgood ,but my problem i can't get any thermal pads here at all , so laptop fan is alternative
same with the fan
same with the fan
before the modd my minimum temp is 50-55 C
1 - i add the fan and only the silver heatsink and test it for small time
2 - idle temp is 52 C and normal working CPU about 30%-40% 58-60 C
3- stress the CPU for two minutes temp became 78C
4- i stopped the stress test to not damage the device.
5- i disconnect the fan (small but so noisy)
6- 2 - idle temp is 54 C and normal working CPU about 30%-40% 58-60 C so no benefit from the fan
7- i stick the second (golden) heatsink to the alu plate
8- and now Idle 1s 55 and normal usage about 30%-40% 60-65 C
conclusion is :
- fan i useless at least for me
- the most important part is the silicon thermal pads under the board touch down the box
unfortunately i can't find it any where i have to order it online and it will take almost 25-30 days to reach here.
so now i will use it with only heatsinks and to keep eye on the temp till i get the thermal pads
Why can you not get any therminal pad??
same with the fan
Today I tried astress test with AIDA64 trial. I have an unmodded pipo. The cpu temp went up to 83C with AIDA not reporting any CPU throttling. Then I tried moving the mouse and it gave me an 100% cpu throttling spike and the graphics driver reported that it crashed and recovered succesfully. After that the temps lowered a little to 78C and stayed there with no cpu throttling reported. I stopped the test after about 6 minutes. After some minutes I restarted the test and temps stayed about 76-78C with no reported cpu throttling.
I can't make anything out of it...
Originally posted by kgian76 View PostToday I tried astress test with AIDA64 trial. I have an unmodded pipo. The cpu temp went up to 83C with AIDA not reporting any CPU throttling. Then I tried moving the mouse and it gave me an 100% cpu throttling spike and the graphics driver reported that it crashed and recovered succesfully. After that the temps lowered a little to 78C and stayed there with no cpu throttling reported. I stopped the test after about 6 minutes. After some minutes I restarted the test and temps stayed about 76-78C with no reported cpu throttling.
after testing and checking even fan is useless , the main point is to use a good thermal conductive pad under the board to touch the surface of the metal plate down .
using heatsink will just drop the temp for 5 - 7 C alone that's it.
Fisrt, hello to all. This is my fisrt post.
I have been reading the post for weeks. I have a Pipo X7 and very very happy. But it reach 80C very easily.
I am from Spain and in summer we have 40C in shadow. 80C in the pipo is a risk in summer.
I have try the heatsinks mod (8mm tall aluminium) and the thermal pad in the back. My conclusion, the more important is to join the mother board and the aluminiun case of the pipo.
With the heatsinks, the temperatures was very similars. The main different was a better cooling differential. That is, a high velocity from high to low temperature.
With the pad in the back, but without case contact, was a 2-3 C different.
But with the pad in the back and with case contact there was a 10C different. In normal use, the pipo is in 55C. With a high load, the pipo reach the 80C - 82C again, but only with high load.
Then, I have try to control that intensive puntual hight temperature. The idea is to help the pipo in that moments (in a HD film or playing a game). I have a USB fan, that for laptops. I put then under the pipo, and in the high load test, the temperature drop to 70C!!!!
I use the USB fan to insert air from the room. The room was to 20C or 22C. I insert the air from the botton of the pipo.
But....
Then I think in the pipo case desing. From the first time I have seen the pipo I missed something in the top: a grating. The air in the pipo enter by the botton and then goes to the sides. But in the top there has not a exit. That is a problem in passive cooling.
With this in mind, I think in turn arround the pipo. I put the botton in top, and then.... surprise, 10C temperature down fall without the fan. In high load the temperature was 70C to 72C. Ok, after a while it reach to 80C, but then you return to normal load and the temperature goes down very quickly.
And then I put the USB fan. But this time on top of the pipo (that is the botton) and throwing out the air. And in high load this time the temperature was 60C (20C less!!!!). And in normal load over 45C.
I use the XT 1mm thermal pad cut in five parts, and I put one over other. I take one 5mm pad and put in the back middle. The contact with the case is between 4mm and 5mm.
Now, when I have time, I will mod the upper case to open a grating, but by now the pipo is flipped.
Originally posted by pitiocampa View PostFisrt, hello to all. This is my fisrt post.
But....
now i know what i want , only thermal pads and flip it over
i will try that when i got the pads
There are currently 2973 users online. 0 members and 2973 guests.
