Maybe you have malfunction in your PMIC or a very bad cpu!
Heatsink modding
Got steady 12.4V when measured power input with a voltmeter.
Now i just need to print out a cover for the fan and start using the box instead off modding all the time.
Originally posted by Trhuster View PostNo i don't have any other powersupply to test with. But seems to work good now, i cut out a hole in the case and still 60c after around 1 hour.
Originally posted by Scooby-Doo View PostSome guys have problems with mainboard Re. 1.3, wich you have, too.
I have Rev. 1.2. Maybe your temp problem has something to do with that.
Please, how can we check that ? (any picture ?)
Thank you !
EDIT : ok maybe I've find it on my motherboard, is it that ?
So I've rev 1.3 here or what ?Last edited by Pelliculart; 23 February 2015, 17:46.
Originally posted by loko View PostYou will open the device, unscrew the PCB, remove the metal plate, remove the black adhesive from the metal plate, clean the metal plate with alcohol, mix two equal parts of the two tubes of Arctic Alumina Thermal Adhesive and use it to attach at least 4 or even all 10 heatsinks on the metal plate, being careful to attach them according to the right airflow direction, parallel to the long side, let it dry, put one piece of Phobya XT 1mm thermal pad on the processor, one on the power unit and a long one on the memory chips, and replace the metal plate. It will be better if before closing the device you put a piece of a 5mm thermal pad on the other side of the processor and the power unit. You do not need the thermal paste.
With my X7 after watching youtube for a while my x7 throttles like crazy.
Originally posted by Scooby-Doo View PostThe more W/mK, the better. I used 7/mK
But i'm not a scientist, only my thoughts.
There are currently 2087 users online. 1 members and 2086 guests.
