(Source: http://farm8.staticflickr.com/7523/1...21eb6f769b.jpg)
I would replace the pads there with some with much better/higher W/mK because I think pipo use cheap ones with maybe 1 - 1.5 W/mK...
Because of the CPU I would use pads with only adhesive film at one side...
Also I wouldn't use the paste but a thin pad as replacement at the heatsinks (because I think they also use cheap pads at this kind of cheap "baby" heatsinks with also worse W/mK) and here of course with adhesive film at both sides...
I guess this is hard to follow because I don't have the device yet. So under the metal plate it already has thermal pads to transfer heat from the cpu to the metal plate, and you are saying that you recommend replacing those pads with higher quality ones, is that correct?
Now I thought scooby doo, recommended attaching additional finned heatsinks to the metal plate for additional heat dissipation, and that I would need adhesive thermal paste for that. Are you saying that instead of paste you would recommend attaching additional heatsinks with thermal pads that have adhesive on both sides? I guess I don't really follow this:
Do you have links for any of these things? I really have no idea what to buy now.
This sounded simple at first but I think this may be beyond my abilities...
I just thought about a probably better solution. Grab some copper pad having the same dimensions as the cpu silicone pad, especially the same height, permanently attach it on the internal side of the included heatsing, exactly where the cpu silicone pad exists, using a thin layer of thermal adhesive compound, and apply a thin layer of plain thermal compound over the cpu to achieve the best possible contact. After that, you can attach 10 mini heatsinks on the external side of the included heatsing using thermal adhesive compound.
2. You can fix the heatsinks directly on the surface af the chips without the metal plate.
Important: Use only a small drop of the thermal adhesive and smear with the plastic reusable mixing wand over the heatsink surface. It must be a ultra thin layer. Than fix them, so that no drops can fall beside of the chips on the mainboard.
Sorry for my bad English.
keine probleme , English or Deutsch
you are help and support others , and not all of us here our mother tongue is English
you are the main contributor here for Heatsink modding.
Thanks!
I think I will try affixing the heatsinks to the metal plate, applying them directly to the chips scares me.
What thickness is the thermal pad covering the chips? Would .5mm replacement pad work? Or should I try replacing them with copper?
You have to try. Copper is a better heat conductor.
For me I ordered some small copper platelets because I planned to change the small blue pads with them and I want to place some over the ram chips, too, because they have no contact with the heatsink arrangement.
