Heatsink modding
just find old heatsink and 'glu' it with Electrolube non-silicone heat transfer compound HTC10S (I use that because it was available at work)Last edited by tamonegdje; 03 March 2015, 08:03.
Could these heatsinks would be a good and cheap option to make the mod???
http://www.****.es/itm/10-Pieza-Alum...item2ed290e271
My Pipo X7 is not going to be working 24 hours per day...... I only want to decrease the temperature in a cheap way.
Originally posted by albmart View PostCould these heatsinks would be a good and cheap option to make the mod???
It would be helpfull to fill zhe complete surface of the alu plate with the heatsinks (maybe you need two pachets of`em). Maybe it would be necessery to use additional air cooling with those low budget heatsinks. You must place the cooling fins parallel to have a good airflow, and even without a active cooling. arrange them parallel to the front side (like one big cooler). Don´t forget to put the cooling pads, like discribed earlier in this post.
First step: - install the cooling system passive, how you planned it.
Second step: - do along term benchmark and watch the temperatures -> If they stay below 65 ° C
everything is fine. Over 65 degrees throttling of the cores begins (See the thermal bios options). than you would have to think about placing a fan into your box.
There are different ways to accomplish a proposal.
To give you more ideas I give you a link to another box, I modded:
Originally posted by albmart View PostThanks a lot for your answer Scooby-Doo!
I would use thermal pads too, but I can't find any cheap (The thermal pads that I have found and are cheap, are adhesive thermal pads, but someone here talked about that adhesive pads are not recommended for this purpose...).
Originally posted by Scooby-Doo View PostThe heatsinks you should fix wirh thermal adhesive. The thermal pads are under the alu plate to get contact to the chips. But everything is described in earlier threads.
Thanks again, perhaps sometimes I don't explain very well what I want to sayAnd sometimes I confuse technical English words, like heatsink, thermal pads, ......
So, the modding would be....
1- We open the Pipo and we have the CPU, cooling pad, and a Alu plate
2- Put thermal adhesive on the alu plate
3- Put the heatsink on the thermal adhesive
4- In the other side of the mainboard, I can put thermal pads to get contact with the chips.
If I have understand everything, I think that I'm right with that.
I have 2 questions:
1- Is the same Thermal pad as Cooling pad?
2- And in step 2..... can I use thermal adhesive pads instead thermal adhesive?
Thanks a lot for your time and your patienceLast edited by albmart; 04 March 2015, 11:37.
Or simply put them on chips and after cover with alu plate?
Thanks in advance
Originally posted by Vestiaz View PostOne basic question about that, thermal pads need to be fixed with some adhesive?
Thanks in advance
The pad for the backside of the mainboard doen´t need fixation.
Originally posted by smokie171 View PostThanks to Loko for the insight and help. Thanks to Scooby-Doo for your mod, as you can tell I modeled my mod after yours.
Originally posted by albmart View Post2- And in step 2..... can I use thermal adhesive pads instead thermal adhesive?
Thanks in advance
Originally posted by Scooby-Doo View PostYes. E.g. with arctic cooling two compound thermal adhesive on both sides.
Originally posted by loko View PostIf you fix the thermal pads permanently, you will not be able to reopen the device. There is no need to fix the thermal pads, since they get compressed by the metal plate and stay in place anyway. Just be sure that you select the right thermal pad thickness. Properly compressed thermal pads always stay in place, but the most significant aspect is that they have much better thermal behaviour than poorly compressed ones.
I ordered this thermal pad 1 mm: http://www.****.es/itm/121159893475?...=STRK:MEWNX:IT
My plan is doing like this mod: http://www.noelshack.com/2015-09-142...9-img-4492.jpg
And more noob questions
Fixing the heatsinks to alu plate already mounted or better unmounted?
How much and what thermal paste use? problems with holes of alu plate?
Thanks in advance
there is no reason to replace the thermal adhesive pads under the alum plate. My mod is averaging temperatures of 42 degrees with programs running and 38 degrees with no programs running. All I did was add 2 30x30x25 mm heat sinks and a 5 mm thermal pad. There is no reason to take off the aluminum plate covering the CPU as it can only lead to problems. You can read the post earlier from Loko. explaining this to me. My advice is to keep it simple. Good luck
There are currently 1737 users online. 1 members and 1736 guests.
