Heatsink modding
Suggestions please
Hey guys,
I found in my box of IT junk an old cooler off a Sapphire x1650 video card and I was wondering if one could suggest a way of mounting it in the case.
it is 64mm x 102mm x 13mm
does anyone have any ideas about mounting it? Does anyone have the dimensions of the aluminum plate?
I already tested it with a usb 5v power supply and it is quiet while pushing enough air to make a difference...
I think passive is the best way to go with a heatsink and pad. I used an old 12mm heatsink off an old motherboard and the 5mm thermal pad which keeps running temps under 58C at 100% load. The Pipo X7 with a small Bluetooth keypad is an excellent very quiet computer for low level gaming or general use. On the down side I can see the wife looking at how handy it is coupled up to my TV so it may be reassigned to her tv :-(
Ken.
Originally posted by scropion86 View Postanybody here have tested or used Thermoelectric Peltier Cooler before
it looks able to make the CPU and chips more Cool
http://en.wikipedia.org/wiki/Thermoelectric_cooling
You will have to dissipate more heat : the heat from the CPU plus the heat from the peltier... so you'll need a bigger heatsink and probably active cooling
Originally posted by CRi View PostSure, the CPU will be cooler... but the hot end of the peltier will be warmer than the CPU !
it start making ice in between the CPU and the heatsink.
and this will lead to short circuit , dead Pipo
hello guys,
I apologize for my bad English,
thank you for all of you who made this thread,
especially to Scooby-Doo!
I received my box before few days
and for that purpose I bought I love it!
But like many of you I have problem with temperature,
when I use Chrome and watch some flash youtube my box hits 85 C.
Now I waiting my orders to make this mod ,
I hope not mistake buying them
this one I will put on the bottom
http://www.****.com/itm/251753770292...%3AMEBIDX%3AIT
and these will stick on the alu plate on the top
http://www.****.com/itm/5pcs-30x30x1...19&mfe=sidebar
Am I right direction?
Thank youLast edited by Vinchenzo; 09 March 2015, 12:18.
Originally posted by hey69 View PostLooks good. If you have some spare copper or some metal parts at home.you can allready maybe try to put on top of the metal plate and see if that helps till your **** order arrives ( i did it and fixed it with some tape )
Thank you
thank you very much for your time Kevin, too late I saw your post I had ordered those, but I can order and these
http://www.****.com/itm/200802051035?redirect=mobile
What you think,these have to fit better?
Thank you
Originally posted by Vinchenzo View Postthank you very much for your time Kevin, too late I saw your post I had ordered those, but I can order and these
Thank you
Kevin
Ok,I got it,
2 pieces it's maximum space,I guess
http://www.****.com/itm/131132044387?redirect=mobile
Thank you again
There are currently 3089 users online. 0 members and 3089 guests.
