Ainol Windows 8.1 Mini PC Intel Z3735D
    There are a lot of Intel Bay Trail based mini PCs out there, and there are a lot more to come. Most of them use the Intel Z3735F processor, while PiPo X7 uses the slightly faster Intel Z3736F processor.
    Ainol Windows 8.1 Mini PC deserves a separate thread, because it uses the Intel Z3735D processor which has native USB 3.0 support.
    The USB 3.0 port will probably offer the possibility to exploit the full potential of Gigabit Ethernet adapters, mechanical hard drives and USB 3.0 Flash Drives, which could be important especially in the case this device would be also used as a NAS.
    PROS: USB 3.0 port, built-in 7000mAh battery, elegant design.
    CONS: Probably inadequate cooling due to design, lack of Ethernet port.
    Since adding a USB 3.0 Hub and a Gigabit Ethernet adapter will increase the total price considerably, I think that PiPo X7 with a custom heat sink and a price close to US $100 probably remains the best choice overall.
    It will be nice to find out more information about Ainol Windows 8.1 Mini PC and its performance when it will be generally available and thoroughly tested.
    Seems overkill for a charger... sorry
    2mm more height than a VOYO.
    Cheers
      This one has a rely nice look to it & it has usb3 now thats more like it,I think it wont be long before we see them coming with 4GB ram & 64 rom as the norm
        Looking at Geekbuying not much air circulation going on there.
        Uses the usb 3.0 micro-B plug.
        Cheers
          Intel Z3735D
          also only supports max 2GB RAM....
          But, if I don't misunderstand "Aluminium alloy", maybe better cooling mod solutions (via thermal pads) than the VOYO...
          So it could be a nice toy...
          What's about the BIOS? I bet 32bit...
          RK3288 Devices
          - Overview BOX (LINK !)
            New comer Ainol Windows Mini PC Intel Z3735D 1.83GHz 2G RAM 32G ROM WIFI 7000mAn Power Bank USB 3.0 OTG Bluetooth
            here is a new Win8.1 TV box Ainol
            Ainol Windows Mini PC Intel Z3735D 1.83GHz 2G RAM 32G ROM WIFI 7000mAn Power Bank USB 3.0 OTG Bluetooth - Black
              my guess is they decided to RUSH these out to market.. no dobut a whole bunch of 'em sat on the west coast USA during the west coast port strike! this comes as many tablet companies are looking to go where the demand is (away from android).. and because google's android/linux OS isn't evolving fast enough (many days lat ver 5.0 and a few hundred features short) x86 pc's have a window of opportunity with TV-HD/UHD PC (versus the old PCTV) boxes as consumers figure out how to deal with their cable companies screwing them.
              I think these specs would be reasonable for under $200
              2.5ghz quad core + gpu with 1gb gddr 5 onboard and can share
              4gb ram (for $10 more they can make the design to support laptop so-dimms x2 @16gb max)
              64gb (128gb, 256gb respectively in 2016)
              5v 3a /12v 5a switchable (support & power nas)
              hdmi in/out x2 (auto & 4k support @ 60frame 240hz)
              attachable cooling solution (moving or not) accessory
              4 usb 3 ports
              802.11ac
              bt 4
              SD latest spec
              gigabit ethernet port (aka google fiber ready )))
              All this and a pathway for upgrading to windows 10... that's worth btw $100 and $200
                4 usb 3 ports
                802.11ac
                bt 4
                SD latest spec
                in other words a 200$ barebone mini-pc /nuc.....
                ok I'm in.
                  Apart from the USB 3 port and built in battery/charger, I noticed one other potential advantage of the Z3725D over the Z3735F.
                  The maximum CPU temp allowed is 105C instead of 90C, which, bearing in mind the cooling issues that too many of these seem to exhibit, may be have advantage in terms of box longevity.
                    Yes could be good news just checked the Intel www mentions 105 in the chart I read but as you say
                    a higher melting point has to be good
                    Cheers
                      have anybody already bought it and received it? review, anyone?
                        Yep iv got one it arrived today, love this little thing already I should have a review by the weekend
                        Blinkone
                          USB 3 Micro
                          To use the USB3 micro port may need something like
                          Cheers
                            Blinkone
                            great! can't wait to read it
                              Day One Ainol Windows 8.1 Mini PC Intel Z3735D.
                              Well now that I am hooked on these Intel devices.
                              I have the Ainol Windows 8.1 Mini PC Intel Z3735D.
                              Thanks to Geekbuying for their excellent service and delivery of this unit. http://goo.gl/EIhZEc
                              Whats in the Package,
                              Code:
                               [TABLE="class: jbEidtTable, width: 740"]
                               	 		[TR]
                               		[/TR]
                               		[TR]
                               			[TD="align: left"]Brand[/TD]
                               			[TD="align: left"]Ainol[/TD]
                               		[/TR]
                               		[TR]
                               			[TD="align: left"]Color[/TD]
                               			[TD="align: left"]Black[/TD]
                               		[/TR]
                               		[TR]
                               			[TD="align: left"]Material[/TD]
                               			[TD="align: left"]Aluminium alloy[/TD]
                               		[/TR]
                               		[TR]
                               		[/TR]
                               		[TR]
                               			[TD="align: left"]Operating System[/TD]
                               			[TD="align: left"]Windows 8.1 with Bing authorised edition[/TD]
                               		[/TR]
                               		[TR]
                               			[TD="align: left"]CPU[/TD]
                               			[TD="align: left"]64-BIT Intel Btry Z3735D, Quad core, up to 1.83GHz[/TD]
                               		[/TR]
                               		[TR]
                               			[TD="align: left"]GPU[/TD]
                               			[TD="align: left"]Intel HD Graphics[/TD]
                               		[/TR]
                               		[TR]
                               			[TD="align: left"]RAM[/TD]
                               			[TD="align: left"]2GB DDR3L[/TD]
                               		[/TR]
                               		[TR]
                               			[TD="align: left"]ROM[/TD]
                               			[TD="align: left"]32GB eMMC[/TD]
                               		[/TR]
                               		[TR]
                               			[TD="align: left"]Extended Storage[/TD]
                               			[TD="align: left"]Micro SD card, support up to 128GB[/TD]
                               		[/TR]
                               		[TR]
                               		[/TR]
                               		[TR]
                               			[TD="align: left"]Wifi Connectivity[/TD]
                               			[TD="align: left"]802.11 b/n/g[/TD]
                               		[/TR]
                               		[TR]
                               			[TD="align: left"]Bluetooth[/TD]
                               			[TD="align: left"]4.0[/TD]
                               		[/TR]
                               		[TR]
                               			[TD="align: left"] [/TD]
                               		[/TR]
                               		[TR]
                               		[/TR]
                               		[TR]
                               			[TD="align: left"]Video Supported[/TD]
                               			[TD="align: left"]AVI(1920 x 1208), 3GP(352 x 288), MP4(1280 x 720), MKV(1920 x 1208), MOV(1920 x 1080), MPG(720 X 480), VOB(1024 x 576)[/TD]
                               		[/TR]
                               		[TR]
                               			[TD="align: left"]Audio Supported[/TD]
                               			[TD="align: left"]WAV, MP3, MIDI, AAC, APE, MP2, AMR, etc.[/TD]
                               		[/TR]
                               		[TR]
                               			[TD="align: left"]Picture Supported[/TD]
                               			[TD="align: left"]JPG, BMP, PNG, GIF[/TD]
                               		[/TR]
                               		[TR]
                               		[/TR]
                               		[TR]
                               			[TD="align: left"]HDMI Port[/TD]
                               			[TD="align: left"]Mini HDMI female, 1.4[/TD]
                               		[/TR]
                               		[TR]
                               			[TD="align: left"]Other Interfaces[/TD]
                               			[TD="align: left"]1 x USB 3.0; 2 x USB 2.0;1 x Micro SD card slot;1 x 3.5mm Earphone jack[/TD]
                               		[/TR]
                               		[TR]
                               		[/TR]
                               		[TR]
                               		[/TR]
                               		[TR]
                               			[TD="align: left"]Other Function[/TD]
                               			[TD="align: left"]3-axis G-sensor, high sensitivity
                              			OTG function, support exfat, NTFS, Fat32 partition and other USB device
                              			Built-in 7000mAh[/TD]
                               		[/TR]
                               		[TR]
                               			[TD="align: left"]Power[/TD]
                               			[TD="align: left"]input: 100~240vac; output: 5V,2.5A[/TD]
                               		[/TR]
                               		[TR]
                               		[/TR]
                               		[TR]
                               			[TD="align: left"]Dimension[/TD]
                               			[TD="align: left"]115 x 146 x 14mm[/TD]
                               		[/TR]
                               		[TR]
                               			[TD="align: left"]Weight[/TD]
                               			[TD="align: left"]335g[/TD]
                               		[/TR]
                               		[TR]
                               		[/TR]
                               		[TR]
                               			[TD="colspan: 2, align: left"]1 x TV box[/TD]
                               		[/TR]
                               		[TR]
                               			[TD="colspan: 2, align: left"]1 x HDMI cable[/TD]
                               		[/TR]
                               		[TR]
                               			[TD="colspan: 2, align: left"]1 x Power adapter (A right AC Adapter will be sent as your shipping country)[/TD]
                               		[/TR]
                               		[TR]
                               			[TD="colspan: 2, align: left"]1 x Warranty card[/TD]
                               		[/TR]
                               		[TR]
                               			[TD="colspan: 2, align: left"]1 x User manual[/TD]
                               		[/TR]
                               	 [/TABLE]
                              Think I am going to need a can open I feel to get inside this compact device.
                              This is a very compact and solid unit. Using the Intel Z3735D others are using the Z3735F
                              Both CPU’s much the same tho according to Intel, D model has a higher Tjmax @105c and 7F is @90c so you can ride this one 15 degrees more before it will melt, In theory. I recall most of the CMOS have settings set to about 90c.
                              Device running couple of hours doing updates, much the same as other units,
                              WIFI speed good. Ainol is using realtek chipset for WIFI/BT.
                              Stressed tested for 20 minutes Using Aida64 the Outer case is warm only, Temps in the 60c, Startup Temp around 40~45c.
                              Power Pack supplied one of the smallest DC pins I have seen in awhile for a device like this no chance of plugging the wrong plug into this Device
                              24 hours is over and I must say this little unit is equal I find to all the others.
                              After many hours of usage the Tightly Packed Tin Can is warm and that's about it
                              Temps hover in the 50~60 and it keeps on going.
                              The battery is great, ideal for portable use 7 hours and still just under 20% to go
                              I have done all the backups and configuring as seen in the VOYO or PIPO thread,
                              Also removed the Chinese Language so its now all English, have the Safe mode
                              menu in place so looking good. The Ainol also had its own Boot Logo but i like to see what is going on when booting easily disable this feature in CMOS.
                              The Unit does not come with the USB3/OTG port may need something like
