Ainol Windows 8.1 Mini PC Intel Z3735D
I bought this a 5V 3A adapter from aliexpress and it is able to power the Ainol. In case you need a backup power adapter.
After receiving my Ainol this week, I've changed some BIOS Settings (without creating an BIOS backup before) and now I'm unfortunately not able to get into my BIOS and reset the Default Settings anymore. For doing this, I would need the Original BIOS Image File, wich can easily created by performing the following steps:
1) Download and extract the Windows based AMI AFUWIN Flasher 5.05.04 (afuwin-5.05.04) archive from wimsbios.com/amiflasher.jsp to Disk C
2) Open the extracted afuwin32 folder, run the afuwingui.exe as an administrator, press "Save" and save the Ainol BIOS Image File (afuwin.rom) to Disk C
I would very much appreciate it, if any of you could follow this 2 steps and provide this file.
Thank you very much for your help!
P.S.: Resseting the CMOS / BIOS Settings can be done with the same tool, by performing the following steps:
1) Press "Open" and select the backuped BIOS Image File (afuwin.rom)
2) Uncheck "Main BIOS Image" and check "NVRAM" instead
3) Press "Flash"
4) Access the BIOS and press F3 to reset the factory defaultsLast edited by ascona; 25 November 2015, 04:20.
There are currently 2313 users online. 3 members and 2310 guests.
