Ainol Windows 8.1 Mini PC Intel Z3735D
    Originally posted by twiddler View Post
    You're the greatest - many thanks for your help!
    With your backup file, I've just been able to access the BIOS again and to restore the settings I've carelessly changed before.
    If someone who reads this, is actually faced with the same problem: just download the Afuwin Flasher tool and follow the steps listed above.
    Thanks again, twiddler for your help!
      Glad to help
        Shame you cant get drivers for these, I really liked mine.....
          somehow i terminated my Bios - could you please re upload this file ? It cold be my last chance with this device !
          Thanks a lot
            Try this link mate..
              I make wrong bios settings to. Please help:
              ... I've changed some BIOS Settings (without creating an BIOS backup before) and now I'm unfortunately not able to get into my BIOS and reset the Default Settings anymore. For doing this, I would need the Original BIOS Image File, wich can easily created by performing the following steps:
              1) Download and extract the Windows based AMI AFUWIN Flasher 5.05.04 (afuwin-5.05.04) archive from wimsbios.com/amiflasher.jsp to Disk C
              2) Open the extracted afuwin32 folder, run the afuwingui.exe as an administrator, press "Save" and save the Ainol BIOS Image File (afuwin.rom) to Disk C
              I would very much appreciate it, if any of you could follow this 2 steps and provide this file.
              Thank you very much for your help!
              P.S.: Resseting the CMOS / BIOS Settings can be done with the same tool, by performing the following steps:
              1) Press "Open" and select the backuped BIOS Image File (afuwin.rom)
              2) Uncheck "Main BIOS Image" and check "NVRAM" instead
              3) Press "Flash"
              4) Access the BIOS and press F3 to reset the factory defaults
              AMI Flasher utility - AFUDOS, AFUWIN, AFULNX, AFUEFI - Download all available AMI flasher versions - DOS/Windows/Linux • Wim's BIOS
              https://www.wimsbios.com
              Download all AMI BIOS Flasher utility (AFUDOS, AFUWIN, AFULNX, AFUEFI) versions from Wim's BIOS
