[RECOVERY][K200] OFFICIAL TWRP 2.8.5.1 touch recovery [06.03.2015]
    Team Win Recovery Project 2.x, or twrp2 for short, is a custom recovery built with ease of use and customization in mind. Its a fully touch driven user interface no more volume rocker or power buttons to mash. The GUI is also fully XML driven and completely theme-able. You can change just about every aspect of the look and feel.
    Phone look:
    Tablet look:
    CHANGELOG for 2.8.5.0:
    -Scale the GUI - TWRP can read the theme's resolution and scale it up or down to fit the theme to your screen's resolution
    -Backups can now be cancelled while the backup is in progress (does not include restore because we don't want to leave your device in a bad state)
    -Improve thread handling and move input handling into the main rendering thread to improve stability
    -Make MTP work even if unplugged and plugged back in
    -Unify scrollable list code and make kinetic scrolling feel more natural
    -Fix handling of mapped zip files for OTA updates (CM12 updater)
    -USB keyboards should now work on all devices that support USB host mode via a USB OTG cable
    -Other small fixes and improvements
    CHANGELOG for 2.8.4.0:
    -Add flashing of boot and recovery images via the TWRP GUI (Find the Images button on the Install page)
    -Fix some MTP related crashes and bugs
    -Eliminate TWRP toggling USB IDs during boot if MTP is enabled
    -Fix various adb sideload issues
    -Improve threading of actions
    -Eliminate separate thread for screen timeout
    -Update libblkid to 2.25.0
    -Use power button as back button on watch themes for easier navigation
    -Add mutex locking to data manager
    -Improve custom theme handling on encrypted devices
    -Allow the stock theme to be offset by build flags so we can center a lower res theme on a higher res screen especially for watches with round screens
    CHANGELOG for 2.8.3.0:
    -MTP will now tell the host PC that storage is removed instead of disabling MTP completely
    -MTP will now report the correct max file size based on the file system in use to the host PC (may fix transfer of large files)
    -Update and improve fix permissions and make fixing contexts optional
    -Update SuperSU in TWRP to 2.40 and update install process
    -Make TWRP work properly on AArch64 (Nexus 9 is now built in true 64-bit binaries and libraries)
    -Attempt to set correct permissions and contexts on all files placed in storage so backups will show in Android
    -Fix kernel panic during MTP start on some devices
    -Support unicode fonts on devices with True Type Font support
    -Fix slider value not showing sometimes (vibration settings page)
    -Toggle MTP off during adb sideload to set correct USB IDs
    -Reduce library requirements for 5.0 L decrypt
    -Other minor fixes and improvements
    Note: Starting with TWRP 2.8.2.0 and higher, adb sideload uses a new sideload method originally implemented in AOSP recovery. You will need the latest adb binaries to use sideload in these newer versions of TWRP. The version required is 1.0.32. You can find the version by running "adb version" on your computer. The new sideload feature no longer stores the zip on your device. Instead, a fuse file system is created in RAM and the zip is streamed from your computer. This puts less wear and tear on storage and ensures that large zips will not fill up all of your RAM. The sideload may spit an error on your PC side, but the zip should install just fine on your device.
    CHANGELOG for 2.8.2.0:
    -Pull in all changes from Android 5.0 lollipop into TWRP
    -Add decrypt support for Android 5.0 lollipop encrypted partitions including automatic decrypt when the default_password is in use
    -Revert some changes to exFAT that were breaking exFAT support on some devices
    -Other minor fixes and updates
    Note: At this time we do not have a GUI representation for pattern unlock. You can still decrypt patterns though by translating the pattern dots to numbers. The pattern dots correspond to numbers in the following pattern:
    1 2 3
    4 5 6
    7 8 9
    So an upper-case L would translate to a password of 14789 entered on the keyboard. Eventually we plan to add a proper pattern unlock to TWRP but it is a relatively low priority at this point.
    DOWNLOAD:
    Most devices can be updated quickly and easily with the TWRP Manager app:
    Play Store Link
    1) Install TWRP Manager from the Play Store
    2) Open TWRP Manager and provide root permissions
    3) Hit Advanced->Install Recovery
    4) Verify the correct device name on your screen then press Install Recovery if the correct device is showing
    OR:
    You can find more information and download links on our website!
    BUGS:
    If you have found a bug, please consider posting it to our github issues log. It's pretty much impossible for us to keep up with the more than 40 threads that we have for the devices that we "directly" support. If you have a significant problem that cannot be answered in this thread, your best bet is to PM me directly, contact us via our website, or find us in our IRC channel below. If you see someone that's struggling, feel free to point it out to us. We need your help to help us keep track of all of our devices! Thanks!
    SUPPORT:
    Live support is available via #twrp on Freenode with your IRC client or just click this link
    if [ $up.post.type = $type.two.lazy.to_use_google ] || [ $up.post.type = $type.silly_question ];
    then mv $user.contact.up.post /.trash; set response($response.type = ignore);
    $user.up.post.ignore_in_future = true; fi;
    [RECOVERY][K200] TWRP 2.8.5.0 touch recovery [26.02.2015]
    Great new thread! Well done, Abdul!
    Edit:
    Question:
    This should work even on the smallest Mxq s85 and Mk808b Plus?
    Inviato dal mio Nexus 5 utilizzando Tapatalk
      If you can run the k200 FW available on the official thread, them yes. But i think it's not compatible.
      Thanks, but i just submitted the device tree upstream.
        On the other side: could this work on a high end MXIII PLUS ( squared one ) with Aml S812 and 2/8 Gb ? I have one coming in a week time!
          For the MXQ S85: no, I believe it has a different board reference, never mind, we have the version that Daemonium modified for this device, but... should be good to see an updated version! Will ask in the right thread. Thanks
            no luck
            I am currently on twrp 2.8.1.0. When I try to update to 2.8.5.0 using twrp manager I get a blank choose version to install page after selecting recovery version to install. Is this normal? Or am I doing something wrong?
              I tested on stock rom and the option was there, maybe you have a different build.prop ?
              Nerveless you can download the image and use the second method.
              Download the above file. Save it to the root of your removable SD card and rename it to recovery.img Power off the device then power it on while holding the reset button.
              If you wish to replace the stock recovery, boot the recovery image from your SD card as above. Go to Install -> Images... then browse to your SD card and select the recovery.img, choose recovery and swipe to flash.
                Thanks for the reply. I have a tronsmart Vega s89 running finless 2.1. Can the second method be done using a USB stick by any long chance!?
                  I don't think USB boot is supported, but you can try
                    I flashed with rashr app but now my problem is the aspect half screen missing
                      Pull recovery.log.
                      'Adb pull tmp/recovery.log'
                      Tapatalked
                        Will do tomorrow thanks for swift reply.
                          Here it is
                          MEGA provides free cloud storage with convenient and powerful always-on privacy. Claim your free 50GB now!
                            My TV is 720p by the way
                              Does not work with the version of the recovery stage, a blank page opens.
                              console tronsmart S89-H,the stock firmware from the official site of 111K4
