I just downloaded the image abdul_pt gave above (k200.img), renamed it recovery.img, put it on USB, and tried again. Holding the reset, I turned box on and waited until recovery booted. I picked "apply update from EXT," then selected "update from udisk." But then it asks me to "choose package to install." The recovery.img is not even showing up. What am I doing wrong?
[RECOVERY][K200] OFFICIAL TWRP 2.8.5.1 touch recovery [06.03.2015]
Originally posted by Dandroid534 View PostDoes this work with mxiii 2gb/8gb 115k4
Originally posted by tommyguns818 View PostHello. Just got new mxiii box with build number KOT49h. This box will not flash anything when doing the microsd card/toothpick. Can I download twrpx.x.x.recovery.img and rename it recovery.img and flash it via USB burning tool? Oh and Google play isn't being friendly either. Thanks
Originally posted by londonshore View Post
we are on the same boat buddy mxiii 2g x8gb i have done everything .... flashed images using usb burning tool ... im able to get the box to 115k4 but then wifi wont work ... our boxes are garbage and i think fakes ... ive been at it for 4 days .. im still arguing with suppler in china about this and he keeps trying to send me firmwares which are garbage,, and not original 101k4 -115k4.... one i find a way i will share same firmwares come on all 10 boxes buddy hang in
Wow. Thank you. Sorry about your 10 boxes...ouch. Yes it seems like the Vendor in china or whatever put some lame Rom on here and making it difficult to change Roms and boot into recovery. Luckily I bought from amazon and Im returning it and buying another from someone else on amazon. But I'd still love to find a way in case it happens again. I have done like 4 of these boxes and went like a breeze installing custom rom/recovery.
i have good old abdul helping me ... hope he figures it out or else im screwed with these 10 and shipping to china is 95 usd so lose money and who know when ill get my money back so a fix is needed amazon is the way to go
Thanks for the quick response and hello mr. abdul. So im very terrible at adb shell/terminal use. When this or if happens again with new box, would flashing twrp recovery.img like I previously mentioned through USB burning tool work? Have you heard or know anybody that successfully have done that? Many thanks!!!
@Abdual_pt
I'm a bit confused, have the rules changed somewhat recently? I was under the impression that, One was to copy the renamed recovery.img to the MicroSD, and not to to the ExternalSD.... (i.e. For all other tense the internal storage)? I've been telling some of these Guys to use the MicroSD, which was the way I was told... BY YOU Once, not so long ago... IIRC, and now the instructions say to use the ExternalSD
Thanks.
XXXp://www.tronsmart.com/?p=2241(remove the x's).
After that you can finally flash what ever you want via sd card method. EDIT: This method has broken wifi. Internet cord works though. Even tried different roms and still wifi is still trying to search. Hopefully there's a quick patch zip to fix in near future.Last edited by tommyguns818; 28 June 2015, 19:38.
Got it to work by using the 115k.img and usb burning tool v2.0.3 from THIS site only. Other versions didn't work for me...In usb burning tool, you must select force erase all.
After that you can finally flash what ever you want via sd card method. Wow.... finally
does your wifi work?
There are currently 2155 users online. 1 members and 2154 guests.
