[RECOVERY][K200] OFFICIAL TWRP 2.8.5.1 touch recovery [06.03.2015]
    Originally posted by saor11 View Post
    My TV is 720p by the way
    You aren't using the official TWRP image. This thread is about the official image.
    Please remove the theme folder from SDcard and try again.
    if [ $up.post.type = $type.two.lazy.to_use_google ] || [ $up.post.type = $type.silly_question ];
    then mv $user.contact.up.post /.trash; set response($response.type = ignore);
    $user.up.post.ignore_in_future = true; fi;
      Originally posted by dimarik83 View Post
      Does not work with the version of the recovery stage, a blank page opens.
      console tronsmart S89-H,the stock firmware from the official site of 111K4
      Please provide recovery.log.
      Latest version is 112k4, from Beelink witch also runs on the Tronsmart.
        Theme folder won't delete
          Hello Abdul, I own now a MXIII PLUS original from Beelink ( wireless chip is AP6335 ), Rom installed 201K4, 2Gb/8Gb ram. Board is N200 from Netxeon, do You think one of this thread Twrp will work?
          Inviato dal mio Nexus 5 utilizzando Tapatalk
            So when your SDcard is full what do you do ?
            Flash a new FW ?
            I'm working on the scaling issue. TWRP renders /dev/graphics/fb0 witch is always 1920x1080 on the k200.
            Tapatalked
              Can your run the FW from the official thread of the s82 ?
              Tapatalked
                Flash a new FW ?
                Tapatalked
                I went to the twrp folder in the internal SD which contains two folders one backup the other theme. The theme folder would not delete say's cannot be deleted when I try. Won't matter now my TV is 720 it won't scale right for me .
                  @Abdul Pt: I have not got what You mean with:
                  "Can your run the FW from the official thread of the s82 ?"
                  Do you mean the Twrp FW?
                    The scaling issue is fixed. Download the new image that it will work.
                    Something is wrong with your rom, why wouldn't you be able to delete a folder from the SDcard. I'm running 112k4 and i have no problems.
                      I mean if you can run the FirmWare from the Official Thread them this image will also work on your device.
                        Updated to 2.8.5.1 to fix the non scaling issue.
                          I am running finless 2.1 111k4 I changed build prop to k200 as he left it in there if you wanted to use it instead of the nexus 10 spoof he has to work around some play store compatibility on some apps. I flashed the newest IMG as you say rebooted into recovery got a striped looking screen. Anyway got back to the finless twrp zip he supplied.
                            What i can say is that i'm running 112k4 on a Beelink s82b and tested this feature on a HD and an SD TV without a problem.
                            I flashed TWRP, booted to recovery connected to the HD TV got a proper scale GUI. Rebooted to system, connected to the SD TV and rebooted to recovery. Again got a proper scaled GUI.
                            So the problem is fixed.
                            Tapatalked
                              I have the same issue.
                                Can you provide more info?
                                Device ?
                                TV and connection type(HDMI/AV)?
                                And log.
                                Tapatalked
