Mk802 III Finless ROM ?
    As for my ROM.
    Big question here. Do you want the ZIP format or flash tool. I am saying this because if you want me to repartition nand for more app space (since you have 8GB to work with) it must be via flash tool. I really do not like making 2 different kits especially since we really cannot afford the bandwidth for download anymore.
      Personally I'd rather have the zip file so I can just upload it to my sd card and flash but its up to you. I just appreciate the hard work you put into this
        well more app space would be a nice thing, I have already run out of space. so this would mean no zipfile, right?
        if it would support logitech F710 or xbox controller and also droidmote (uinput.ko) then it would be a perfect solution
        thanks for your work
          Xbox controller will be no problem to add. uinput should already be there!
          It is not possible to repartition NAND with zip file so yes it would be using the flash tool.
            Flash tool is fine. I was able to load your mx1 rom this afternoon without any issues. Great job on the rom!
              I have one more little issue, I don't know if it could be handled in the ROM or some other way:
              Some games do not detect mouseclicks and cannot be played (e.g.: Bad Piggies, Ski Safari, Dragon Slayer). Other games work fine.
              So if it's a rom issue, could you fix it please.
              Thank you for your effort.
                As for my ROM.
                Thanks Bob for your continual support. From a selfish point of vihew i'd prefer the flash method every bit of nand space available for apps has to be a good thing..... Explain this to me Bob, loading your rom using a zip file.... does sit along side the original OS or is it overwritten?..... Using the flash tool, does this wipe the whole nand space and give use the whole 8 gig to use.... what I'm asking is using the zip file off of the sd, will this reduce the 802-3 to a total of 4 gig of nand space?.... sorry for my ignorance on the subject. I'm just trying to get my head around how nand space is partioned when flashing one of yor roms.
                Maplins... thanks for the tip....they also sell a lot of over priced crap....
                  gabb, thank you very much.
                  Thanks to all one more time, specially to Bob
                    There is a new firmware version for mk802 III
                      Just released now? Link please?
                        How to edit update.zip , If i add or del file from update.zip ,re-sign or not ,Both can't be recognize by system, It told me not and valid update.zip file
                          As for my ROM.
                          Flash tool is a good thing, because I would prefer the repartitioning for more space
                          Thanks in advance for your work!
                            If you can squeeze in a TUN.KO to allow VPN to workplaces that would be awesome.
                            I do this every day on MK802ii but the 802iii I have doesn't do it
                            Thanks for great work.
                              Password to extract w2comp link is: w2comp.com
