Mk802 III Finless ROM ?
    Hi Bob,
    Any update on how the mk802-III ROM is coming along?
    And in the meantime what would be the best ROM for the mk802-III out of the ug802 1.7 and the mk808 1.6?
    Slightly baffled by the actual differences between all these devices!
    Many thanks for you efforts!
      Originally posted by catt View Post
      Hi Bob,
      Bob, after I flash 1.7, I just can get start screen, and stop there. looks like update not fineshed. what can i do right now. the flash tool could find it any more. Please give a hand.
        the start page (ug802) just freeze there. no android page. is there any other flash tool can force flash? because I use the tool you give it could not find any device.
          take a look here:
            is anybody know how to flash it back from finless 1.7 to factory img
              Here is solution:
              It really works
                Any news updates about the Rom? Is it still in the pipeline?
                  Windows 8 installation driver
                  Originally posted by patfrank View Post
                  Have you installed the latest update from Rikomagic? sounds like it may not be rooted. I had the same problem, did a factory reste then installed the update and then had to use another computer as my laptop with Win 8 did not work. Good luck
                  Have you tried the 'Disable Driver Signature Enforcement' option? Like in this video? Maybe it helps...
                    I would like to add my hopes/prayers and dreams to this post.....
                    Running ug802 1.7, and it seems ok. Would love to know if we could get USB bluetooth support with an 802III rom. Poking around in the Finless 1.7, I see some bluetooth stuff, but it doesn't look like any of it is active?
                    Is there any hope? Or are we better off scraping this one and buyng that neo X5 I saw you review, Finless?
                    Paul
                      Bump
                      Paul
                      Bump.....Anybody...Anbody....Bueller......
                        I've sucessfully flashed finless 1.7 on my MK802III. So far so good, it works nicely.
                        But it's all rather small to read on 1080p. Setting font size to huge already helped a bit, but not enough. So I decided to increase the dpi settings to 240. Unfortunately I tried with 2 different tools, and twice ended up with an ususable result.
                        Did anybody succeed to increase the dpi settings?
                          Edit build.prop
                          Change lcd.density to 160
                            @Finless: Any news with your MK802IIIS rom?
                              @Finless, i installed the 1.7 on my Mk802 III, what happens if i want to go back on a stock version? It's enough to put the update.zip on the sdCard as before? Or it will mess something related to new kernel?
                                I do not believe the stock update.zip flashes the stock kernel when placed on sd card and use recovery. However if you use the RKbatch tool and flash the update.zip using restore button, it will flash the kernel.
