iMito MX1/2 - Finless ROM 1.5 - Root, debloat, init.d support
Re: NEW - iMito MX1/2 - Finless ROM 1.5 - Root, debloat, init.d support
Originally posted by Playonlover View PostAll installed, beautiful Picture. Using MX Player and had to tweak settings to avoid some lag, but MX Player runs perfectly now!
Thanks Bob
Just for us to learn...
Sent from SGS III GT-I9300 🙋🙎🙍🙇🙅🙌
Wake after soft power off
I like the soft power off feature, however I can't figure out how to wake it up after I powered it off. Is there some kind of key combination I am missing? I hope I don't have to unplug it and plug it back in just to get it out of power off mode, otherwise the whole feature would seem kind of useless.
Originally posted by stayindoors View PostWhat is the solution to the following error when performing step 4 "Reboot to flash mode":
Error "device cannot do flash mode, because of no drive".
Thanks!
Thanks!
Try this:
7) If the unit does not reboot to a blank screen and into flash mode it maybe stuck.
In my ROM kit is another folder called alternate_reboot_to_flash_tool
This is the RKBatch tool. Run this tool and the 1 box should be pink.
Click the "switch" button at the bottom and this should put it into flash mode.
Close this RKBtach tool now.
Originally posted by Jbardi View PostI like the soft power off feature, however I can't figure out how to wake it up after I powered it off. Is there some kind of key combination I am missing? I hope I don't have to unplug it and plug it back in just to get it out of power off mode, otherwise the whole feature would seem kind of useless.
Originally posted by Jbardi View PostI like the soft power off feature, however I can't figure out how to wake it up after I powered it off. Is there some kind of key combination I am missing? I hope I don't have to unplug it and plug it back in just to get it out of power off mode, otherwise the whole feature would seem kind of useless.Originally posted by sstavross View PostUnfortunately you have to unplug it and plug it back...
@finless
hi bob,
i found somebody to help me with the driver for the usb0501 lan2usb adapter...
what i would need now is to know what kernel source and (compile) config you are using?
could you please provide me a link?
last time you just said i should try the standart jellybean kernel, but i don't know which one you mean :S
also in the threads are many kernels mentioned and i'm lost... :S
is this the right one:
if yes what is your config? do you have a config.gz?
best regards, thx 4 the help and merry christmas,
toby
Totally noob stupid question, and I apologize.. but...
I am reading the instructions - - how do I connect the MX1 to the PC in such a way that I can manipulate the MX1's menu system?
When I plug in the MX1 - it only recognizes it via storage - - not in any way that I can access menus to change settings such as mass storage etc.
Am I doing something wrong?
Please advise...
There are currently 9075 users online. 3 members and 9072 guests.
