if i'd wanted cutting edge blisteringly fast tech, id have bought a device 3-4x the price of this one.
ROM work for Archos 80 Cobalt?
people will always argue.over whats faster, just like they whinge about battery life (for gods sake, you have a pocket sized computer!) but i dont give a toss about a few points gained on a benchmark test!
OK so maybe time for me to help.
Do you guys want parameter files for different setups of user space?
I'll probably be able to look at this tomorrow evening. I'll put my cobalt on charge and will be able to test flash. Can also look at swapping the sdcard too.900Supersport
freaktab developer
This parameter file will give 6 gig app space.
Code:FIRMWARE_VER:1.0.3 MACHINE_MODEL:ARCHOS 80 COBALT MACHINE_ID:007 MANUFACTURER:RK30SDK MAGIC: 0x5041524B ATAG: 0x60000800 MACHINE: 3066 CHECK_MASK: 0x80 KERNEL_IMG: 0x60408000 #RECOVER_KEY: 1,1,0,20,0 CMDLINE: console=ttyFIQ0 androidboot.console=ttyFIQ0 init=/init initrd=0x62000000,0x00800000 mtdparts=rk29xxnand:0x00002000@0x00002000(misc),0x00004000@0x00004000(kernel),0x00008000@0x00008000(boot),0x00008000@0x00010000(recovery),0x00100000@0x00018000(backup),0x0003a000@0x00118000(cache),0x00c00000@0x00152000(userdata),0x00002000@0x00d52000(kpanic),0x00100000@0x00d54000(system),-@0x00e54000(user)
For safeties sake make a backup of the parameters file900Supersport
freaktab developer
Re: ROM work for Archos 80 Cobalt?
Here's the vold.fstab
Code:## Vold 2.0 Generic fstab ## - San Mehat ([email protected]) ## ####################### ## Regular device mount ## ## Format: dev_mount <label> <mount_point> <part> <sysfs_path1...> ## label - Label for the volume ## mount_point - Where the volume will be mounted ## part - Partition # (1 based), or 'auto' for first usable partition. ## <sysfs_path> - List of sysfs paths to source devices ###################### ## Example of a standard sdcard mount for the emulator / Dream # Mounts the first usable partition of the specified device #dev_mount sdcard /mnt/sdcard auto /devices/platform/goldfish_mmc.0 /devices/platform/msm_sdcc.2/mmc_host/mmc1 #dev_mount flash /mnt/sdcard auto /devices/virtual/mtd/mtd9/mtdblock9 dev_mount flash /mnt/sdcard auto /devices/platform/rk29_sdmmc.0/mmc_host/mmc0 #dev_mount sdcard /mnt/external_sd auto /devices/platform/rk29_sdmmc.0/mmc_host/mmc0 dev_mount sdcard /mnt/external_sd auto /devices/virtual/mtd/mtd9/mtdblock9 dev_mount udisk /mnt/usb_storage auto /devices/platform/usb20_otg/usb ## Example of a dual card setup # dev_mount left_sdcard /sdcard1 auto /devices/platform/goldfish_mmc.0 /devices/platform/msm_sdcc.2/mmc_host/mmc1 # dev_mount right_sdcard /sdcard2 auto /devices/platform/goldfish_mmc.1 /devices/platform/msm_sdcc.3/mmc_host/mmc1 ## Example of specifying a specific partition for mounts # dev_mount sdcard /sdcard 2 /devices/platform/goldfish_mmc.0 /devices/platform/msm_sdcc.2/mmc_host/mmc1
900Supersport
freaktab developer
Yes, not tried the xda app but had no problems so far with tappatak, Facebook and carbon.900Supersport
freaktab developer
I get a package file not valid error on the xda-developers app.900Supersport
freaktab developer
Firstly, great thanks to 900supersport and the site for providing more valuable assistance with the Cobalt.
I've applied the parameter file will to give 6 gig app space and that seems to work well.
I also tried to apply the vold.fstab option but on booting the tablet sat on the start-up screen with loading ... flashing across the top of the screen and no further progress, so I'm not sure if I have done something wrong there but cannot get that to apply.
I've noted a few additional things about the new ROM:
1. Battery usage seems to be far higher and rather than getting up to 5 hours of general use, I am now getting less than 3.
2. The volume rocker switches are now reversed.
3. When performing a back-up using CWM to the external card, the process seems to run correctly but when I examine the contents, there are are 5 files:
boot.img (16 mb)
cache.ext4.dup (5k)
data.tmpfs.dup (9b)
nandroid.md5 (238b)
recovery.img (16mb)
system.ext4.dup (196k)
I would expect the backup to be in the hundreds of megabytes, so don't know what is preventing the back-up from completing successfully.
I did try the back-up to the internal SD but there wasn't enough space for it.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
I don't use the cobalt too often so have not noticed the battery issue.
The six gig apps space and vold where done and tested on the original ROM, again I've not tried this on the new ROM. It would make more sense to look at the vold I posted and compare with that on the new ROM, with a but of luck an edit on the two lines for the sdcard should see you right.900Supersport
freaktab developer
There are currently 1887 users online. 1 members and 1886 guests.
