OLD MK808/MK808B/MINIX Hybryd FW V2.2.2 (25.04.2013)
Mouse problems
I use mk808 with 2.2.2 . Wifi slow... but I have Razer Deathadder 1800 dpi mouse. When i simply move mouse i see 30% !!! cpu usage. For what? I see this big slowdown on games to. When stop mouse move everythings works fine.
Second. Is there any way to change this fancy mouse cursor to default?
Anyway this is the best performance rom. 9640 Antutu.
Everything is possible if we work together!
ethernet at boot shoud work out of the box:"
im usung "unitek 100 mb usb2.0" and its working almost all the time.Everything is possible if we work together!
Originally posted by lewy20041 View Postthx.
i dont know why i cant edit my own treads:"
MK808 USB BT Kernels:
http://adf.ly/OAvQi 720p
http://adf.ly/OAvlW 1080p
Modules RK3066:
Code:Select all rtl8711.ko; nls_utf8.ko tun.ko; ath3k.ko; hci_vhci.ko; bfusb.ko; bcm203x.ko; btmrvl.ko; btmrvl_sdio.ko; ath.ko; plusb.ko; pl2303.ko; gspca_main.ko ;gspca_sonixj.ko; sunrpc.ko; auth_rpcgss.ko; lockd.ko; r8712u.ko; mcs7830.ko; rt5370sta.ko; rtl8192cu.ko; cp210x.ko; ftdi_sio.ko; nfs.ko; ntfs.ko; 8723au.ko; cx82310_eth.ko; dm9601.ko; smsc75xx.ko; smsc95xx.ko
I wanted to have USB BT capability on mk808, so I tried to flash that kernel above.
RKbatchtool is giving me error that "load FW failed", anyone else having this issue?
And .img file has mk808B in its name. Is this the right file for non B model?
Thanks again
flash using finless tools its kernel not the whole firmwareEverything is possible if we work together!
Any help?
With 2.2.3 problem not solved.
Originally posted by qwertz View PostI use mk808 with 2.2.2 . Wifi slow... but I have Razer Deathadder 1800 dpi mouse. When i simply move mouse i see 30% !!! cpu usage. For what? I see this big slowdown on games to. When stop mouse move everythings works fine.
Originally posted by pestul View PostThanks for your efforts. I'll try this out when I get home from work (2.2.3) and donate as well. Any way to enable ethernet on at boot yet?
Download Script Manager from the Play Store, then set it to auto run on boot, you'll always get an IP after reboot.
You will have to add an .sh to the file's name in order for SM to work with it.
Edit: Will also take around 45 seconds, since it's supposed to be used at boot and has a delay, it's fixable if you open it up in a word program.
Originally posted by lewy20041 View Postethernet at boot shoud work out of the box:"
im usung "unitek 100 mb usb2.0" and its working almost all the time.Currently Using:
2 x Nvidia Shield TV | MiniMX III
Retired Devices:
MiniMX III-II | Mk808b Pro | Mk808b Plus | Raspberry Pi 1 + 2 | UBOX R89 | MK808 | MK808b | CS008 | X1 4K (rk3288_809) | CYX_809III | Ouya | CX-919 | S82 Plus | Tronstmart R68
Flashed 2.2.2 on my test MK808 and ran great(will test 2.2.3 soon). The speed is excellent and haven't had any problems with either wifi or ethernet. Flashing it now to the one my wife uses for movies, Angry Birds, and surfing the internet in the kitchen. I am running the 720P version but strangely get better performance with the screen settting at 1080. Have it set to performance and overheating is no issue at all.....altho this helps:
Here are some pics of my "custom" case in progress made from an old HDD enclosure - I'm sure many of you have one of these (I have 2 - only 1 had a fan tho).Last edited by Horrorzilla; 08 May 2013, 03:18.
Nice mod, i'm also looking for a case to mod for the moment im using a rad from athlon xp64 with copper core and copper rad for chipset on other side.
im on lewy 2.1.1 with 2dark kernel; and only one antenna not connected to ground; i was looking for an old cdrom case 5.25 but you give me idea with this hdd case.
Good job and congrat i hope to post some pic one day too
and thanks too to Lewy
Just tested the updated 2.2.3 rom -2.2.2 definitely ran slower and choppier(at least for me)than 2.2.3. Antutu also read about 600 less and videos thru MXPlayer Pro were not as smooth and it had a hard time downloading and installing multiple play store apps. I had both versions set up the same - performance, noop, 1920x1080 using the 720p version. Lewy ~ awesome fix, I recommend everyone try 2.2.3
Thanks a ton for the great work Lewy ! !Last edited by Horrorzilla; 07 May 2013, 23:51.
Originally posted by Horrorzilla View PostJust tested the updated 2.2.3 rom -2.2.2 definitely ran slower and choppier(at least for me)than 2.2.3. Antutu also read about 600 less and videos thru MXPlayer Pro were not as smooth and it had a hard time downloading and installing multiple play store apps. I had both versions set up the same - performance, noop, 1920x1080 using the 720p version. Lewy ~ awesome fix, I recommend everyone try 2.2.3
EDIT: Im a dumb. I went back a page. derp derp.
I am however having an issue accessing the DevHost site. I normally can access it but right now it keeps coming up as a bunch of code like there is a site issue or something.Last edited by Spotopolis; 08 May 2013, 21:31.TV Stick: MK808 // Tronsmart T428
ROM: Finless 1.7c w/Pimp My Rom // Nexus SDK2 Multi-Window v1.2
CPU: @1.6GHz OnDemand Governor NOOP I/O Scheduler
Recovery: ClockworkMod
Kernel: Omegamoon // 1080p OC kernel 720ddr 1.9cpu
Phone: Samsung Galaxy Note II
ROM: Whompasaurus v4.2
Kernel: Persus
There are currently 2764 users online. 1 members and 2763 guests.
