OLD MK808/MK808B/MINIX Hybryd FW V2.2.2 (25.04.2013)
Originally posted by leolas View PostYou must install a custom rom now, you loose your boot, so need a pc and install any custom rom, finless Rom or lewy Rom for your device. Choose 1 of them, read the readme inside and flash it.
If you want to make experiments with boot or any sensible partitions I suggest first intal cwm, make a backup, and then experiment.
thanks, I got it back up and running, I didn't have to wait for the usb a male cable as I was advice to use the same usb power cable as the otg usb cable to connect to the pc. I flashed the beta JB 4.22 and it's working great, so right now I'll do some more research and see how to install the cwm recovery before I do any other boot.img testing. I also would like to research on replacing the /data internal partition with a ext4 second partition on the sdcard (64gb is a lot for user files so that would be great if it could be done).
thanks again for your replies.
new ver in next week:
changelog:
V2.2.2
-better performance
-faster boot up
-youtube for gtv updated to 1.6
-tv launcher
-build.prop fixes
-screen auto scale to 100%
what you woud like me to add in next ver?
feedback wantedEverything is possible if we work together!
Originally posted by lewy20041 View Postnew ver in next week:
changelog:
V2.2.2
-better performance
-faster boot up
-tv launcher
-build.prop fixes
feedback wanted
XBMC Xperience 1080 with New skin.
TV Stick:MK808
changelog:
V2.2.2
-better performance
-faster boot up
-tv launcher
-build.prop fixes
feedback wanted
The 720p, 1080p kernels in .zip format, so you can easily switch resolution in CWM. I know this may cause problems with the boot image, but totally worth it as a way to switch from 720p to 1080p easily.Currently Using:
2 x Nvidia Shield TV | MiniMX III
Retired Devices:
MiniMX III-II | Mk808b Pro | Mk808b Plus | Raspberry Pi 1 + 2 | UBOX R89 | MK808 | MK808b | CS008 | X1 4K (rk3288_809) | CYX_809III | Ouya | CX-919 | S82 Plus | Tronstmart R68
-xbmc will be preinstaled, configured and set tu auto start in diffrent firmware
-cwm (this will take some time but its planed)
-there will be 480p, 720p and 1080p (480p will dont support usb bt dongle)Everything is possible if we work together!
C270 logicool Camera
changelog:
V2.2.2
-better performance
-faster boot up
-tv launcher
-build.prop fixes
feedback wanted
Hello,
The rom works great too.
I have some concern, my C270 logicool camera and mic will work flawlessly on my MK808B
if connected to OTG port not on the normal USB ports. Is this Normal?
Thank you
ricont
changelog:
V2.2.2
-better performance
-faster boot up
-tv launcher
-build.prop fixes
feedback wanted
changelog:
V2.2.2
-better performance
-faster boot up
-tv launcher
-build.prop fixes
feedback wanted
And it would be good to have titanium backup.
PaulTV Stick:MK808
Originally posted by lewy20041 View Postwith hex editor delete firs 8 blocks of boot.img and open with 7zip tu pack you need cygwin or linux.
if you know cygwin a litle i can send you my scripts to pack unpack boot.img.
to swap sdcards you can edit /system/etc/vold.fstab
The scripts you provided me did not work in the first try I did with the first boot.img I extracted with the 'cat' command. It didn't work either with the second boot.img I extracted with the MK808B CWM Backup. So I am stuck at the moment. If you did swap the sdcards, how did you accomplished it ?
changelog:
V2.2.2
-better performance
-faster boot up
-tv launcher
-build.prop fixes
feedback wanted
There are currently 1622 users online. 4 members and 1618 guests.
