OLD MK808/MK808B/MINIX Hybryd FW V2.2.2 (25.04.2013)
    jus use google.
    gtalk.apk:"
    Everything is possible if we work together!
    ApkFreak
      Originally posted by staats View Post
      After installing the 720p version of this rom on my mk808 my WiFi stops working after a few minutes. Any idea on what might be going on. I don't have any problems with the connection with any other rom except the oem one. The rom with the best connection so far has been with the Hybryd 720p 2.1.3 rom.
      if you dont mind usb bt dongle support flash kizs kernel for better wifi performance.
      ApkFreak
        Thanks Lewy20041 for your reply
        I don't mind no bt support but I don't know how to go about flashing your rom with the kizs kernel. I am really new to all this
          FW2.2.2+MK808B+Sixaxis with Touch emulator
          Thanks Lewy for your great Hybryd 1080p ROM V2.2.2
          This ROM works great with my MK808B with Sixaxis app I can emulate touch profile work with my fake PS3 controller without any problem. Bluetooth work good and WiFi works a lot better than V2.2.0. Do you have any plan to make ROM for gaming? It will be great...
          What I like this ROM
          - Build.prop make device compatible to Google play to download many game like DH4, The conduit HD, etc better than stock ROM
          - Already added Touch emulator. This great for Sixaxis Touch emulator
          - WiFi works great with good signal
          Can you please include screen snap shot it will be easy to capture screen of game to make Sixaxis touch profile. Also overclock CPU & GPU for gaming performance...
          Thank you for your great ROM
            screen snap shot is in setting m8
            Settings/ScrenshotSetting/ and click Show the Screnshot button in the statusbar
            TV Stick:MK808
              Thanks...I also just figure it out.
                -modules loaded at startup:
                ethernet 1000M chipsets - not supported .....................
                  Upgrade from v2.2.0 to v2.2.2
                  Please advise on how I must do to upgrade. I tried but the new version was installed as a fresh copy. I had restored to my backup.
                    Amazon VOD
                    Lewy20041 -- appreciate all your work! This is an excellent ROM.
                    Do you know if it is possible to get Amazon VOD working on it? If so, how would I do that?
                      What xmbc version do you recommend for this rom?
                      Do i need neon or non neon?
                        neon
                        ApkFreak
                          my ethernet tu usb is working:"
                          as of modules.
                          there will be a litle change in next ver.
                          ApkFreak
                            Can anyone help me with this? I've been searching the forums and Google for days, but I can't find an answer. I can't be the only person that uses Amazon VOD...
                              need suggestions on USB sound adapters
                              Are there any good support sound adapters or DACs for this ROM?
                              my C-Media USB sound adapter (http://goo.gl/uh2hW) doesnt work.
                              i have checked my sound adapter as output device but the output is still via HDMI.
                              Thanks for your suggestions.
                                This is modified Minix Neo x5 firmware with my tweaks.
                                If anyone have question just ask
                                !Google TV Apps Can Be Downloaded From My Website!
                                My website:
                                http://xbmcfreak.xorg.pl
                                Beta:
                                MK808/MK808B (Fixed)
                                Dev-Host V2.2.2 480p (No BT Dongle support for 480p)
                                Dev-Host V2.2.2 720p
                                Dev-Host V2.2.2 1080p
                                Neo X5
                                Neo G4
                                Cabletech
                                Dev-Host V2.2.2 720p Fixed
                                changelog:
                                V2.2.2
                                -better performance
                                -faster boot up
                                -youtube for gtv updated to 1.6
                                -tv launcher
                                -build.prop fixes
                                -fixed touch emulation
                                -new modules loaded at startup:
                                Code:
                                    8723au.ko
                                    cx82310_eth.ko
                                    dm9601.ko
                                    smsc75xx.ko
                                    smsc95xx.ko
                                V2.2.0
                                -NeoX5 +NeoG4 Support
                                -based on 26.03.2013FW
                                -rooted
                                -build.prop changes
                                -gameloft games fix
                                -logitech C series webcams best suport
                                -virtual touchscreen suport (apps like sixaxis can mapp touch events, degre need to be changed to -90 in sixaxis settings)
                                -usb bluetooth dongle support for mk808 (working randomly)
                                -new bootanimation
                                -stock kernel (you can flash any other kernel but bluetooth dongle will not work anymore)
                                -app space 2gb
                                -more space on launcher screen
                                -cifs auto mount on startup (edit /system/etc/install-recovery.sh and put there your server ip, username, etc. change permisions to rwx --- ---)
                                -libstagefright.so (new for better xbmc and other players compatibility)
                                -youtube for gtv
                                -wallbase (tons of nice wallpapers)
                                -(1080p) LCD Density 240
                                -(480p) fast as hell;p for thous that dont need hd
                                -added Android Tuner
                                -build.prop tweaks (wi-fi, ui, and other tweaks)
                                -es explorer (manage your files with best file manager, auto apk install)
                                -deleted useless aps
                                -fixess i dont remember;p
                                Code:
                                    btusb.ko
                                    xpad.ko
                                    md4.ko
                                    cifs.ko
                                    rtl8711.ko
                                    nls_utf8.ko
                                    tun.ko
                                    ath3k.ko
                                    hci_vhci.ko
                                    bfusb.ko
                                    bcm203x.ko
                                    btmrvl.ko
                                    btmrvl_sdio.ko
                                    ath.ko
                                    plusb.ko
                                    pl2303.ko
                                    gspca_main.ko
                                    gspca_sonixj.ko
                                    sunrpc.ko
                                    auth_rpcgss.ko
                                    lockd.ko
                                    r8712u.ko
                                    fakeinput.ko
                                    mcs7830.ko
                                    rt5370sta.ko
                                    rtl8192cu.ko
                                    cp210x.ko
                                    ftdi_sio.ko
                                    nfs.ko
                                    ntfs.ko
                                    virtual_touchscreen.ntts.ko
                                install:
                                -unpack arhive (anywhere)
                                -start RKBatchTool.exe
                                -put mk808 into flash mode (pres hiden buton and conect mk808 to pc, use usb otg port)
                                -instal proper drivers when windows ask (drivers are in \Rockchip_Batch_Tool_v1.5\Rockchip_Batch_Tool_v1.5 \RockusbDriver)
                                -when you wil see number 1 in green box selec "..." button in right top corner of RKBatchTool
                                -navigate to MK808 Hybryd FW V2.1.2.img
                                -pres restore button in RKBatchTool
                                after instal:
                                thats the things to do aftrer yoy install your rom o mk808.
                                -first bootup will be slower then the next one (android is setting ui)
                                -after boot wait about 3-5 minutes and reboot the device
                                -go to settings>developer options:
                                -change all animations to 0.5x
                                Thanks to:
                                -2dark4u
                                -finless bob
                                -kizs
                                -minix
                                The rom is great, with speed improved. My XBMC HD Play back 720P movie file very choppy. (xbmc-12.1-Frodo-armeabi-v7a.apk and MX Player Pro latest version installed). With MX Player HD 720P movie no problem, but XBMC very choppy.. Please help..
