OLD MK808/MK808B/MINIX Hybryd FW V2.2.2 (25.04.2013)
no. its still 4.1.1Everything is possible if we work together!
Thank you!
Graet new options:
Lewy2041 Hybryd FW 2.2.0
changelog:
V2.2.0
-virtual touchscreen suport (apps like sixaxis can mapp touch events, degre need to be changed to -90 in sixaxis settings)
-modules loaded at startup:
virtual_touchscreen.ntts.ko
Good Work!
ok i just check and it wont work with 2dark4you becouse kernel isnt compatible with new modules insmoded at startup.
to use alex kernel you will need to flash stock boot.img but you will louse all modules that load on startup with difrent kernels.
with kizs v4.1_720 everything looks okEverything is possible if we work together!
Originally posted by Adainair View PostDid you check option "Times" in System tuner ?. Had to use Android Communicator to put it back.. I used No Frills CPU to check CPU speed..
Re: !NEW! MK808/MK808B/MINIX Hybryd FW V2.2.0 !NEW!(13.04.2013)
Goog rom lewy, but I test test it and some suggestions if I can, insmod all WiFi drivers modules at boot cause the system to hangs when you boot with the WiFi dongle inserted, the internal WiFi conflicts with the dongle and freeze the system or force reboot, at least in my stick mk808b(rk903).REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostGoog rom lewy, but I test test it and some suggestions if I can, insmod all WiFi drivers modules at boot cause the system to hangs when you boot with the WiFi dongle inserted, the internal WiFi conflicts with the dongle and freeze the system or force reboot, at least in my stick mk808b(rk903).
i dont have all this wifi dongels so thats why its beta and becouse way the feedback is so important.
what dongle do you have?
is it working for you when you startup the system without it?
startup>wifi turned off >insert your dongle>wifi turned onEverything is possible if we work together!
Originally posted by Adainair View PostAbout a CPU speed, Max is 1GHz if i am good understand System tuner appEverything is possible if we work together!
tested on 0a12x0001
its the moust common oneEverything is possible if we work together!
Originally posted by lewy20041 View Posti didnt write about it but users who are useing externall wi-fi shoud start the system with wi-fi turned off and then inert the dongle, some will need to rename the module to rkwifi.ko and other will need to use other tricks to get it working.
startup>wifi turned off >insert your dongle>wifi turned onREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
There are currently 2054 users online. 4 members and 2050 guests.
