OLD MK808/MK808B/MINIX Hybryd FW V2.2.2 (25.04.2013)
    This is modified Minix Neo x5 firmware with my tweaks.
    If anyone have question just ask
    !Google TV Apps Can Be Downloaded From My Website!
    My website:
    http://xbmcfreak.xorg.pl
    Beta:
    MK808/MK808B (Fixed)
    Dev-Host V2.2.2 480p (No BT Dongle support for 480p)
    Dev-Host V2.2.2 720p
    Dev-Host V2.2.2 1080p
    Neo X5
    Neo G4
    Cabletech
    Dev-Host V2.2.2 720p Fixed
    changelog:
    V2.2.2
    -better performance
    -faster boot up
    -youtube for gtv updated to 1.6
    -tv launcher
    -build.prop fixes
    -fixed touch emulation
    -new modules loaded at startup:
    Code:
        8723au.ko
        cx82310_eth.ko
        dm9601.ko
        smsc75xx.ko
        smsc95xx.ko
    V2.2.0
    -NeoX5 +NeoG4 Support
    -based on 26.03.2013FW
    -rooted
    -build.prop changes
    -gameloft games fix
    -logitech C series webcams best suport
    -virtual touchscreen suport (apps like sixaxis can mapp touch events, degre need to be changed to -90 in sixaxis settings)
    -usb bluetooth dongle support for mk808 (working randomly)
    -new bootanimation
    -stock kernel (you can flash any other kernel but bluetooth dongle will not work anymore)
    -app space 2gb
    -more space on launcher screen
    -cifs auto mount on startup (edit /system/etc/install-recovery.sh and put there your server ip, username, etc. change permisions to rwx --- ---)
    -libstagefright.so (new for better xbmc and other players compatibility)
    -youtube for gtv
    -wallbase (tons of nice wallpapers)
    -(1080p) LCD Density 240
    -(480p) fast as hell;p for thous that dont need hd
    -added Android Tuner
    -build.prop tweaks (wi-fi, ui, and other tweaks)
    -es explorer (manage your files with best file manager, auto apk install)
    -deleted useless aps
    -fixess i dont remember;p
    -modules loaded at startup:
    Code:
        btusb.ko
        xpad.ko
        md4.ko
        cifs.ko
        rtl8711.ko
        nls_utf8.ko
        tun.ko
        ath3k.ko
        hci_vhci.ko
        bfusb.ko
        bcm203x.ko
        btmrvl.ko
        btmrvl_sdio.ko
        ath.ko
        plusb.ko
        pl2303.ko
        gspca_main.ko
        gspca_sonixj.ko
        sunrpc.ko
        auth_rpcgss.ko
        lockd.ko
        r8712u.ko
        fakeinput.ko
        mcs7830.ko
        rt5370sta.ko
        rtl8192cu.ko
        cp210x.ko
        ftdi_sio.ko
        nfs.ko
        ntfs.ko
        virtual_touchscreen.ntts.ko
    install:
    -unpack arhive (anywhere)
    -start RKBatchTool.exe
    -put mk808 into flash mode (pres hiden buton and conect mk808 to pc, use usb otg port)
    -instal proper drivers when windows ask (drivers are in \Rockchip_Batch_Tool_v1.5\Rockchip_Batch_Tool_v1.5 \RockusbDriver)
    -when you wil see number 1 in green box selec "..." button in right top corner of RKBatchTool
    -navigate to MK808 Hybryd FW V2.1.2.img
    -pres restore button in RKBatchTool
    after instal:
    thats the things to do aftrer yoy install your rom o mk808.
    -first bootup will be slower then the next one (android is setting ui)
    -after boot wait about 3-5 minutes and reboot the device
    -go to settings>developer options:
    -change all animations to 0.5x
    Thanks to:
    -2dark4u
    -finless bob
    -kizs
    -minix
    Everything is possible if we work together!
    ApkFreak
    Re: !NEW! MK808/MK808B/MINIX Hybryd FW V2.2.0 !NEW!(13.04.2013)
    will this work with MK802IIIs?
    Sent from my GT-I9100 using Tapatalk 2
      use your device kernel and try.
      i dont have mk802III
      ApkFreak
        Thanks my boy!!!!!!
          Hi Lewy20041
          Thanks for your work and also your site looks down, can you fix it
          Thx
            Originally posted by Adainair View Post
            Hi Lewy20041
            Thx
            free hosts are shitty...
            i will try to put it up again when i will find some free time.
            ApkFreak
              Tried it with Alex kernel .... stuck on bootscreen
                do it boot with stock kernel for you?
                i will check what may be the problem.
                ApkFreak
                  Hi Lewy, yes it did. With Alex kernel it flashes my tv (Sony) a couple of times and it hangs on the bootscreen.
                    i will look into it.
                    ApkFreak
                      bad URL: http://xbmcfreak.xorg.pl/
                        i need to find better host:"
                        ApkFreak
                          Benchmarked and Dual HD playing and recording
                          Lewy24001 you did a great job on this firmware, I ran it through a bunch of standard benchmarks. If anyone wants to take a look at its performance on the MK808B.
                          LINK
                          Also did a screencast of XMBC running 720p over wifi, in HD. I'm pretty impressed, recording HD while play HD, dual core madness!
                          LINK
                          Thanks for the firmware greatness! tabletuser
                            LINK
                            LINK
                            Huh... My808B Antutu score is over 9550 on stock olson rom, cpu @ Interactive 252-1.6.
                              sorry if dumb questions as I'm not sure difference between versions, any of those 4.2.2?
