I'm curious to know your 2d/3d score in Antutu with that kernel.
OLD - USE NEW POST - MK808b FAQ's, includes 1080p
Originally posted by Abducted View Post
I'm curious to know your 2d/3d score in Antutu with that kernel.Currently Using:
2 x Nvidia Shield TV | MiniMX III
Retired Devices:
MiniMX III-II | Mk808b Pro | Mk808b Plus | Raspberry Pi 1 + 2 | UBOX R89 | MK808 | MK808b | CS008 | X1 4K (rk3288_809) | CYX_809III | Ouya | CX-919 | S82 Plus | Tronstmart R68
I'll make a screenshot later.
BTW about 10 years ago i was very active on an overclocking forum. Often when guys said. "I have a very good cooler, it's not getting hot at all!!" that simply meant their heatsink wasn't seated properly and the heat from the CPU just wasn't transferring to the heatsink like it should.
Now im not saying this is the case for you, but if you're using the 2Dark4U kernel with performance governor and it's not getting hot (on the outside i assume you mean), one must wonder...
BTW my MK808 has a heartbeat again.Hopefully i can fully get it back up and running.
- UG007-II with Finless iMito MX1/2 1.7a ROM and UG802 2Dark4U 1080p overclock kernel and USB WIFI dongle.
- MK808 with Finless MK808 1.7c ROM and 2Dark4U 1.4 MK808 1080p overclock kernel.
- MK908-II: XBMC full 1080p playback with a 1080p kernel HERE
Congratulations on the MK808, how did you get that up and running? heatgun?Currently Using:
Retired Devices:
Originally posted by ididmytime View Post
Q: Can I overclock the CPU?
A: SetCPU will overclock it up to 1.4ghz for the original mk808b, and 1.2ghz for the cloned version, bare in mind your device will run hotter so make sure you have cooling to compensate the extra heat. You will need to set the cpu to performance to achieve this, as the device has a built in 1ghz limiter which can only be bypassed doing this. It will still say you are running at 1ghz, but a quick Linpack test will show the overclock has worked. Most devices the max overclock is around 1.5ghz on a custom kernel, so you're not missing out by using the stock kernel for CPU overclocking.
http://www.geekbuying.com/item/MK808...ck-313213.html
Thanks for a great FAQ, sure comes in handy!Last edited by UnicornKaz; 05 May 2013, 19:20.
Originally posted by UnicornKaz View Postthen why does the MK808B is advertised at geekbuying as "1.6GHZ" ?? ( scroll down to the specifications )
They include both the CPU + GPU speed to make 1.6ghz, very misleading.Currently Using:
Retired Devices:
Hehe, yeah i have to agree those are not a must. A simple old wireless (or even wired) USB mouse and keyboard will work.
Of course it's bull$hit that they advertise it like that. The problem is if one person/store advertises it like that, there is no way others aren't going to do the same. When i bought my stick i pretty much had no clue what i had to look for when comparing these sticks. I got the UG007-II because it had an extra micro-USB port and a reset button!!! Turns out the MK808 (and many others) already had that the whole time...
Also if one stick (or store) would be advertised as 1,2Ghz and the other as 1,6Ghz i'm quite sure i would have gone with the 1.6Ghz version.Last edited by Abducted; 07 May 2013, 14:42.- UG007-II with Finless iMito MX1/2 1.7a ROM and UG802 2Dark4U 1080p overclock kernel and USB WIFI dongle.
Oke better late than never i guess.A screenshot of my UG007II with 1080p 2Dark4U UG802 kernel (CPU:1608Mhz, GPU: 466Mhz, RAM:1120Mhz). Governor at performance and I/O at NOOP.
BTW i noticed you forgot to hide your status bar in your benchmarks so they ran at 1280x672 or 1920x1032. I don't think that will have much effect on the results but i run my benchmarks with hidden status bar so 1920x1080 resolution.
I have the same (weird) very high SD card score except for me it's the write speed. Maybe 2Dark4U build in a write cache and maybe Antutu only tests small files. But that wouldn't explain your high read speed though... So maybe we should just subtract 100 points for that.
My 2D scores are even a little lower and the 3D scores are basicly the same. Not sure if that's because of the different resolution or maybe, like you said, the GPU is held back by something, and overclocking it more doesn't increase performance.
Also a EPIC Citadel screenshot:
Last edited by Abducted; 07 May 2013, 17:25.- UG007-II with Finless iMito MX1/2 1.7a ROM and UG802 2Dark4U 1080p overclock kernel and USB WIFI dongle.
I mentioned in the post that it wasn't it in full screen mode, so may score slightly higher, but when you said you have got Epic Citadel to run at 35fps compared to my 28fps I was curious to see if your GPU was running better than mine.
Considering the raw GPU scores are near same, and how difficult it is to get most devices to overclock much higher than 1.5ghz for the CPU, it's a pretty safe bet to assume that using 533mhz for the GPU on 1080p (perhaps 720p) will be near useless, because the CPU is clearly holding it back. Is it worth pushing the CPU much higher? probably not.
Perhaps this is the sole reason the GPU is clocked so low, as realistically only video decoding may benefit, but unless you use XBMC you don't need the GPU that high, as external players play it pretty well already, even on stock 1080p with moderate 1080p content.Currently Using:
Retired Devices:
Well about the GPU being clock so low by default (since it's enough to playback 1080p with most players) might be very true. However for XBMC but also for general 3D gaming a faster GPU definitely makes a difference. Stock 1080p in Epic citadel 27,2FPS vs 36,1FPS with OC kernel. That's quite a difference.
Also you're now basically saying Antutu is THE benchmark to measure 3D performance and since our score is about the same there that would mean our 3D performance in general is the same. However i would say Epic Citadel is a MUCH more real life and better 3D benchmark. I guess Futuremark's benchmark should be quite reliable too, but i have to say for the quality of the 3D it runs at a rather low framerate. But i haven't run that on my UG007II yet. I'll give that a try too.- UG007-II with Finless iMito MX1/2 1.7a ROM and UG802 2Dark4U 1080p overclock kernel and USB WIFI dongle.
Antutu has a pretty good GPU test in it, and is usually pretty reliable with it.
The Ice Extreme benchmark is an absolute crippler, even with the CPU overclock I can't see it doing much more.
Nobody really should of bought these devices for gaming. The only gaming I will do will be via emulation, which is mainly CPU dependent. I don't really play any Android games considering I have a decent PC. I wonder how many actually run in native 1080p?
Think I will stick with 1.4 unless some clever people work out mk808b kernels, and wait until we have a significant upgrade in hardware (probably won't happen for ages). The new quads are too expensive, have the same GPU, and I'm not sure if XBMC supports it, or if it's going to be like the mk802's.Currently Using:
Retired Devices:
Originally posted by ididmytime View PostEthernet Fix/Work Around.
For several roms, if you use an Ethernet adapter, you will not be able to get an IP on reboot. In order to get Ethernet working again, you would have to toggle or reconnect the device. This is not ideal, especially if you use Wifi remotes.
Credit goes to b1g.p0ppa for the commands. I do not claim to be a dev, nor believe this is the proper way to fix this, but it does indeed work. I take no responsibility for your device. This is currently for Finless only, can be made to work on other roms.
You will need this file.
Extract the zip, then place the 01script using a file manager with root permissions in system/ect/init.d.
Reboot, it may take a few seconds after boot to get a connection, depending on what you have running. Congratulations, you can now use Ethernet without toggling off and on.
Issues.
1. The rkremote doesn't work sometimes, other wifi remotes are fine.
2. Breaks some Wifi direct programs (can use FTP Server Ultimate and run as a service to Wifi files over at any time).
3. Do NOT use when Wifi is enabled, it will constantly turn Wifi on and off causing havoc.
4. Sometimes going into the settings causes the Ethernet to turn on and off until you have left.
I have an MK809II with Finless 1.7a 1080p ROM.
ididmytime, I followed this guide completely through and through... great work as it is a great one stop shop for newbie resources.
I was able to get a stream from my PC to run great with few dropped frames on 1080p through MX Player, however when I use XAF, the stream is considerably choppier. I was using XAF Neon for set top. Have you seen this before?
I loaded MX prior to installing XAF, so I'm assuming its using MX to play the content?
There are currently 2107 users online. 0 members and 2107 guests.
