[ROM] RemiX 114k4 for S82/S82B/S82H/MXIII(1G&2G DDR)
Originally posted by vivichoos View PostHi .. just want to confirm if 114k4 will work fine on OTT M8 s802. Also if this already added support for Bluetooth. Version 111k4 and 112k4 did not had the BT option in settings.
I suggest you start by testing the TWRP for the k200 to check if it works, and if it works i would try to flash the this rom but without flashing the bootloader.
No, been working on other projects. One is stable now, and i'm on the finishing steps of another.
But i have also worked on this device, although with less regularity-
Originally posted by Veronica View PostAbdul, you didnt spoof as a nexus 10 right? can you share how to add init.d support and the buffer script please
Code:service initd /system/bin/logwrapper /system/xbin/busybox run-parts /system/etc/init.d class main user root oneshot
Code:#!/system/bin/sh echo 4096 1048576 2097152 > /proc/sys/net/ipv4/tcp_rmem echo 4096 524288 2097152 > /proc/sys/net/ipv4/tcp_wmem echo 1 > /proc/sys/net/ipv4/route/flush echo 2097152 > /proc/sys/net/core/rmem_max echo 2097152 > /proc/sys/net/core/wmem_max echo 262144 > /proc/sys/net/core/rmem_default echo 262144 > /proc/sys/net/core/wmem_default
There are currently 2194 users online. 0 members and 2194 guests.
