[ROM] RemiX 114k4 for S82/S82B/S82H/MXIII(1G&2G DDR)
    Using a Logitech k400 no problem at all also.
    if [ $up.post.type = $type.two.lazy.to_use_google ] || [ $up.post.type = $type.silly_question ];
    then mv $user.contact.up.post /.trash; set response($response.type = ignore);
    $user.up.post.ignore_in_future = true; fi;
      Originally posted by abdul_pt View Post
      If you see a Google TV logo them it's not this rom, because i changed the logo.
      What did you do ?
      What happen ?
      Was there any errors when flashing ?
      Tapatalked
      I went to recovery mode from ROM 113 K4. Then flash your ROM, it said some error in red print as it went so fast and I reboot... It stuck at logo Google TV. I think I brick my Vega S89H. Do you have any links to unbrick it. Thanks
        I can`t downloading whats wrong?or the files down?
          Not much info to give help.
          What did you try to do to restore ? Boot from External SD and flash ?
            Is anyone else experiencing issues playing google play movies? Whenever I try to play something from my library i get only audio no video. I am using an MXIII 1G version running the latest version of this firmware if that makes a difference.
              I installed this rom on my mxiii 2gb and it works good! Mainly I use XBMC and surf on the internet. The only ''problem'' I have with this ROM is that on thehome screen the button that opens the applications page apears white. Also the applications page is white too. I mean that the backround appears white. This didn't happen from the beginning but after opening kodi. Now no matter if I reset the TV BOX the white backround remains. Is there something I have to change on the settings menu or is it a bug.
                Change launcher.
                  Change launcher.
                  which one to install pls..deodex or odex..my box is MXIII 2G/8G??THANK YOU.
                    Odex should be fine... I think deodex is only useful if you want to retheme stuff since deodex Files are IIRC uncompressed odex Files.
                    Thanks for the input.
                    I just didn't include the mbox launcher because i don't like it. I added Google Now just because i had to include one. On some box's i use Smart Launcher.
                    Lollipop we shall see.
                    I kinda agree its not the best looking Launcher 'round. But, it is the best "fit" for this kind of Box. An Android Desktop is just IMHO wrong, on so many levels.
                      I can check, do have any samples/links in mind ?
                      You have a MXIII right ? I just got a PM saying that this Rom doesn't boot on a MXIII.
                      What i can say is that it should work on meson8 k200b 1G, meson8 k200b 2G, meson8m2 n200 1G and meson8m2 n200 2G. This are the DTB files present in the full image.
                      Best way to see this is to just grab the Benchmark Directly from Google's Play Store AnTuTu Video Tester
                      And, again I have the 1G MXIII....
                      I installed your ROM though your TRWP Recovery, Much the same way as I install pretty much any *.zip ROM. For the times I have to flash a stock *.img File, I use Amlogic's USB Burner Tool. If I dislike the "Update"... Which seems more common these days... I flash back to my 110k4 Nandroid Backup again...
                        Change launcher.
                        Hello abdul_pt just falshed your rom which performs well on my MXIII 2G/8G BOX..My question is about the very "HIGH" usage of ram using kodi,spmc,or xbmc gotham oman 13.4.0...is this normal or not would i experience any issues on the high usage of ram ?using three mentioned only 300mb ram left????thanks...is ram usage suppossed to be not lower than 700-800mb maybe..???thanks again...just FYI...BY the way twrp is great...but when i boot to recovery on your rom it wont boot to twrp ??any ideas ,as what i can see its inside your rom already but i guess it didnt flash the recovery when i flashed your rom..thanks...
                          HIGH usage compared to what ?
                          Understand that this is just a mod to 114k4 stock rom. I provided a flashable zip with some tweaks.
                          Android manages resources in a different way, you will never get a high value of free ram.
                          I can't help on TWRP problem, i don't have a MXII, and it seems that for some MXII owners everything works ok and for others it doesn't.
                          Maybe there's some different HW revisions.
                            Confirmed.
                            I get a blank screen but the result is a perfect.
                            What do you think of this launcher ? More of your type, still needs some polishing.
                            EDIT:
                            Testing something that i compiled last week, i have no more blank screen on Video Tester.
                            Screens
                              Dear Abdul...
                              I found something of interest this morning while having a nose 'round the build.prop trying to get a Bluetooth Dongle (USB), to fire up on 109k4... (Again for those that don't know I'm on a 1G/8G Device w/no Bluetooth!).
                              The thing I found was this: "media.amplayer.widevineenable=false"
                              The question I'd like to pose to you, and pretty much everyone else, is why IS this disabled for?
                              Enabling this by simply changing the flag from "false" to "true" will finally enable us to use Google Play Movies IN HD!
                              As it was before I flipped this "Switch" Google Play Movies, would only playback the Audio without any Video AT ALL!
                              Now with that function enabled everythings working? I'm hardly a geek or even modest enough to call myself a scriptkiddie. I'm just about versed in the very basics of Debian Linux. ex: apt-get... lol
                              If I can "see this" then I damned sure know you, and other "Modders" out there could!
                              So I'm guessing there's some major downside here that I haven't been hit with.
                              Any ideas what that might be?
                              Otherwise why hasn't anyone bothered to actually turn this on yet?
                              I can learn to live without a Bluetooth System... This "Bug" however almost netted me an Asus Nexus (Puck), Player, just so I could use these "Services".
                              I look forward to your views on this, and again thanks for your hard work!
                                i dont get a zip file to flash when i extract to sd card
