There are some improvements with LAN speed ... it works with higher speed
[ROM] RemiX 114k4 for S82/S82B/S82H/MXIII(1G&2G DDR)
Originally posted by abdul_pt View PostI have s82b also.
Give me some info, please.
Did you do a full wipe ?
From what rom version were you coming ?
The kernel has a safety measure, when it gets too hot it will throttle down the CPU for cooling.
I might release a deodex version, that will reduce ram usage and allow easier modding. And maybe some other things that might come up.Realy grate work abdul
Originally posted by bajann View Postyes i do full wipe 2 times ,evrithing is ok i update su and install some apps ,i come from rom for s82plusi dont know 201 or something like that ,can u add lite launcher ?
Originally posted by bajann View Posthttp://freaktab.com/forum/tv-player-...-beelink/page3
that is stock launcher for s82plus litehome launcher, 201k4 and 202k4 u can find that launcher in fw ,is realy ok
Originally posted by Ichijoe View PostHow is the playback of WMV2, and RMVB? Normally I found that stock 111~114 Firmwares aren't able to deal with these. Inside the AnTuTu Video Benchmark. Both 109, and 110 however are able to play these... If only somewhat. But from 111 on these tests dont play.
You have a MXIII right ? I just got a PM saying that this Rom doesn't boot on a MXIII.
What i can say is that it should work on meson8 k200b 1G, meson8 k200b 2G, meson8m2 n200 1G and meson8m2 n200 2G. This are the DTB files present in the full image.
Originally posted by doduongI flashed this ROM to my Vega S89H and I stuck on Google TV logo. I can not do a hard reset to stock rom any more. Any help/idea would be appriciated.
What did you do ?
What happen ?
Was there any errors when flashing ?
Tapatalked
There are currently 5440 users online. 0 members and 5440 guests.
