+ ) - instead of - ( + . Is that ok? The positive part is still the centre. Just everything is flipped.
First Day PIPO X8 Mini TV BOX Windows 8.1 Android 4.4 Dual Boot Intel Z3736F Update
Heh ... the company cancelled my order of the power supply. I then decided to look around at stuff I had lying around and I had a power supply that was meant for a Drobo v1 in a box. Polarity was perfect, plug fit great and the Pipo works fine with it. It's a 48 watt power supply which is fine and has all the safety certifications. These plugs must have been in use years ago for NAS devices, LCD monitors and the like. Once you know what to look for they can be found. So all is well except that I can't get the win10 upgrade icon to appear ( even using the various fixes lying around). I also can't blank the screen which would be nice when connected to a TV.
Weird. Try and check if it's correct look for Produkey (Google) run it note down info and re-enter, other than that Gearbest.
CheersLast edited by trebor; 20 July 2015, 08:32.
They Will help may take little time being rhe weekend, you box will run without activation for awhile
There website and a service, Do an aftersales request .http://support.gearbest.com/
Also http://freaktab.com/forum/advertiser...a/gearbest-com you can do a request there about your problem
Cheers
I have received my second Pipo X8. There is the same issue: "Windows is not activated" and "Windows can't activate, try again latter"
I suppose I have missed something. I have just started pipo for the first time. When it asked me for wifi key, I skip this step as my key is long and complex ( I want to enter it latter using my keyboard)
after init, Pipo reboot, I switch on my Wifi internet link giving the key, run Internet Explorer to be sure I have Internet working. I go to "PC info". I see "windows is not activated". I go to "activate windows", click on Activate and get the answer "Windows can't activate, try again latter"
Have I missed something?
thanks
About power supply.
I have not found that the power supply we get is bad. When I run Win8 + my software Minitioune/pipotioune and VLC for receiving Digital TV, decoding and display the video, the CPU% used is just above 50% and consumption is less than 500 mA ( 6 watts). most of time consumption is between 330 and 400 mA.You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Hi Trebor,
I am HamRadio and have developed a software for measuring and receiving DATV (Digital Amateur Television). This software can be used also for receiving standard broadcast satellite. This software can do all measurement on the signal, showing RF level, noise level and constellations. My last development was to create ourself our own USB tuner called MiniTiouner. The software is called MiniTioune. (and specific version for PIPO X8 with big buttons is called "PipoTioune") - all free for download -
As HamRadio wish to send and receive DATV from mobile or portable station, the use of PIPO X8 with my Minitiouner is a very fantastic opportunity.
There are currently 1427 users online. 0 members and 1427 guests.
