First Day PIPO X8 Mini TV BOX Windows 8.1 Android 4.4 Dual Boot Intel Z3736F Update
    As far as xbmc goes which is best, Android or windows?
    I am using Kodi.tv on X8 (64/2G), On a few channels, PBS ThinkTV and smithsonian channels, some movie stutters on Win 8.1, but runs smoothly on android. I am located in US. In general, my experience in streaming media, android is much less taxing on the hardware when compare with window..
    bun
      Hi guys,
      Just registered here as this is so far the best forum I found for this subject! Please forgive my ignorance in advance!
      I am awaiting my Pipo x8 to arrive, and have been finding every possible piece of information I can on any forum/review/video I can find!
      So I should say I am a long time apple user (around 15 years professional audio work) and I'm really not interested in getting into the debate here now, but just so you know, Im not completely technology retarded and I have used windows machines a fair bit, but haven't owned one for a very very long time!
      So with that out of the way!
      I am interested in upgrading to windows 10 before doing anything when it arrives. I have used windows 8 before and wasn't impressed, and I like the look and what Im hearing about windows 10.
      My main question is how is it to upgrade, I can't seem to find a clear answer. Is there a very easy way to just do it all through the Windows updater/downloader/whatever, or do I need to do all this complicated stuff Ive been reading here and elsewhere?
      And if it is just an easy process through Windows, is there then something I need to do with drivers etc?
      Once again forgive my ignorance, Ive been living in the sheltered world of not needing to do weird boots and flash drives in different formats and all that jazz!
      Im just worried about seeing all these posts/threads of this stuff and I don't want to screw it up on the first day I get it!
      Cheers!
      edit : just to say I have gone through this thread, but can't quite figure out if all these methods you are talking about is to fix the issues from having removed android and trying to get it back, or similar stuff...
        OK... The X8 will be delivered with a valid (activated) Windows 8.1 license. This will allow Windows 10 to be made available from MS. Go and run the update until it is current. You will be notified when Windows 10 is ready to be downloaded. When downloaded, just run it. The X8 will reboot a number of times before it is complete. My X8 updated to Windows 10 without incident.
        Review Finless article on what you should do first with X7/X8
        Nvidia Shield (2017 & 2019), A95x Max, WD EX2 NAS
          http://freaktab.com/forum/tv-player-...th-the-pipo-x7
          Great, thanks for the info! And there's no driver issues with you? just a little confused as to why pipo released the win 10 drivers if it's fine just to do it all by update...
          Sorry again, Im used to being sheltered from drivers or firmware etc, except the occasional music equipment firmware updates which is normally very simple and well documented.
            I did this, I've run the windows 10 upgrade 4 times. It gets to about 60% done then says there's an error before restoring back to 8.1. I've given up trying! Any ideas? Windows error code 8007002C
              Hmmm. Sounds like the download file is bad. Here is where you can download it from MS.
              windows 7 iso, how to reinstall windows 7, how to restore windows 7, download windows 7 iso, restore windows 7, software recovery, software restore, operating system recovery, Microsoft software recovery, Windows 7 software recovery, Windows 7 operating system recovery, Microsoft operating system recovery, Microsoft recovery, Windows 7 ISO, Windows 7 ISO image, Windows 7, restore Windows 7, reinstall windows 7, re-download Windows 7, Windows 7 disc image
              Download the 32bit version.
              Note
              IMPORTANT: To upgrade for free, select Upgrade this PC now in the tool. You should NOT be asked for a product key during the upgrade process. If you create a USB and use it to install, make sure to remove the USB as soon as setup begins. If you don't, you may be prompted for a product key. If this happens, remove the USB and restart your PC to continue with setup.
ID:	524452 I did this with the USB drive I still get this error but a bit more detail. It says failed in first boot phase failed during migrate data.
                  Update: I managed to install windows 10 if I told it, "not to keep anything". I installed the PIPO x8 drivers and it seems to be working apart from the auto rotation which at first go I can't seem to re-enable and the windows button in the centre bottom of the touchscreen does not have any effect now. Is this button not used in 10 or have I a driver issue?
                    Do you know someone how disable the LCD screen from BIOS/UEFI menu?
                      Hi
                      As i had purchased the X8 since long time, it work pretty ok. My windows side, as it's application specific i never updated it and turn off all updates as well.
                      But few annoying stuff :
                      The HDMI video level is not the same : in android : it's way to bright and in Win it's ok. Is there a setting in android or so to do ??
                      And i haven't find out to properly root the android section. Which version might work ? And is the only way is to go via usb.. ?
                      thanks
                        No. Adjust your TV set
                        "...And i haven't find out to properly root the android section. Which version might work ? ...?..."
                        Mine came rooted already. Did you check for root? If not, try towel root.
                        bun
                          Hello,
                          Stock Pipo X8, with windows 10 upgrade. I have tried to switch from windows to Android (with the stock .exe) and out of nowhere the tv box entered in a loop with the PIPO logo. Now I can't start neither Android nor Windows. It's stucked in a loop. Any advices? Thank you
                          [SOLVED] - Changing in BIOS the Boot Order and booting from a Recovery disk, solved the problem. The chalenge was to make it boot from the USB Recovery drive made on my laptop, not prior made on Pipo device. But, all in all, it worked.
                            Hi guys,
                            I have received my 64g X8 after a friend had updated the windows to 10.
                            Once I got it home I switched it to Andriod just to see how it went and now when I restart it, it boots up in Andriod.
                            My question is how can I switch back to windows?
                            Thank you
                              Hi and Welcome
                              Do you have the OS Switch in Android .
                                No I dont seem to have that switch
