128Gb max for the Msata.
New: Tronsmart Ara BJ19 NUC-like Mini PC Intel Celeron J1900 Processor
Took delivery of mine yesterday and spent the evening trying to get it to boot. I totally missed the fact it requires DDR3L (low voltage) RAM so failed miserably with not even a beep or screen image appearing.
I'm having a 4GB stick delivered tomorrow and will let you know how I get on.
I also notice that it is quite specific about HDD size as well as SSD. As I only have a 360GB and 750GB spare (as well as a 120GB SSD (somewhere!)) It'll be interesting to see if the stated 160, 320 and 500 sized drives is set in stone as I really can't imagine any modern BIOS that would be so dumb as to require a set size of dirve to be fitted.Last edited by dos_box; 28 August 2015, 12:02.
Originally posted by dos_box View PostTook delivery of mine yesterday and spent the evening trying to get it to boot. I totally missed the fact it requires DDR3L (low voltage) RAM so failed miserably with not even a beep or screen image appearing.
I'm having a 4GB stick delivered tomorrow delivered tomorrow and will let you know how I get on.
I also notice that it is quite specific about HDD size as well as SSD. As I only have a 360GB and 750GB spare (as well as a 128GB SSD (somewhere!)) It'll be interesting to see if the stated 160, 320 and 500 sized drives is set in stone as I really can't imagine any modern BIOS that would be so dumb as to require a set size of dirve to be fitted.
Hoping your 750Gb HDD will work as I am planning on putting a 1Tb 2.5 in it for a start.
Originally posted by LycanWrath View Post
As per the sheet, the required RAM is 1333hz max, don't think 1600mhz will work, be careful
It was just plain DDR3 1333 I had in there. It has to be DDR3L. As I said, I have a stick on delivery from Amazon which will be arriving tomorrow. I shouldn't imagine a higher rated RAM making a differnce, it will just work at the max bus speed. If you get one of these you will find that the supplied 'instructions' are very vague and as with most things coming out of China they seem to have been designed over lunch.
Ooh joy! I've just found a 2GB DDR3L 1600 in my desk drawer
From past experience with boards and mems, its a hit and miss to put higher speed on the board.
Some boards just run the memory at the highest speed in can support while others just do not post unless the memory falls within its specified required specs
The 1600Mhz is slightly cheaper than the 1333Mhz memory
EDIT:
On this website it talks of 1333/1600Mhz
Tronsmart has launched several ARM based TV boxes in the last couple of years, but now they've now unveiled an Intel based mini PC with Tronsmart Ara
while the on official Tronsmart website it talks of 1066/1333Mhz
Guess you will have the final word on confirming the memory compatibility
Well, still nothing. The DDR3L I put in thre tonight seems to have not made a difference, however it may be that it was in my desk drawer for a reason and was faulty to begin with. I don't even remeber what it was I pulled it out of!
I shall wait on Amazon tomorow.
What may also be causing an issue is that I have been trying to set it up on my 7 year old Samsung TV in the living room and I may not be seeing a picture due to HDCP issues, however I haven't seen anything like this since the old Vista day when it used to throw a hissy fit when connecting to anything it didn't like i.e. everything!
I really hope that Geekbuying haven't sent me another duff item. This will be two in a row!
I'm going to pop into my office tomorrow and drag hame a spare monitor and hdmi\dvi adaptor just in case.
I shall keep you all posted.
There are currently 6603 users online. 1 members and 6602 guests.
