Don't know is there are any BIOS setting that could fix this
New: Tronsmart Ara BJ19 NUC-like Mini PC Intel Celeron J1900 Processor
Originally posted by deathwalker9 View PostHi!
8Gb/500Gb/W8.1pro64. All drivers installed.
i have big problem with Realtek PCIe GBE Family Controller.
This device not working normal in windows 8.1 and other OS.
If unplugged 220V cable and run W8.1 - all ok. Speed - 1Gb\s, pumps over 100 MByte in sec. If Win restart - ok. After sleep - ok.
But if shutdown from Win - after up Win problem: "identification", "unknown network" "without access to the Internet". And after the "button on" - LAN not working. Boot from "live usb (WinPE)" - LAN not working...
Off/on cable 220V - LAN ok...
Drivers latest from Realtek. All "green" and all power management in drivers - "off".
(In bios I did not find the settings that affect this problem. Only the choice of OS - "Windows 7" - lan work with such problems. If choice "Windows 8.x" or "Android" - "cable not connected").
Help!
It may be in the BIOS settings? (BIOS latest from Tronsmart site). May be after shutdown from OS BIOS not initialized lan-chip...?
This sounds like a typical issue that can occur when the machine goes into hibernation rather than shutting down and happened to me a while back with a laptop that would not connect to the network upon each start-up.
So it may be worth turning hibernation off to test (-powercfg /hibernate off or powercfg /H off )
Also turn off fast start/fast boot if that is turned on in the BIOS and see if that makes a difference.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Powercfg /H off and turned off the sleep mode in bios. But lan after shutdown not work, only after full power off.
Sleep mode and hibernation normally worked in the old BIOS. But he was nowhere to download.
I found how to set the BIOS to work a LAN after shutdown!
Win10x64. All updates. All drivers. Realtek drivers v 10.3.723.2015
In drivers LAN settings:
green ethernet - off
wake on magic packer - off
wake on pattern match - off
energy saving ethernet - off
Sleep mode not work in new bios and i turned it off:
sleep mode disables in bios - ACPI settings - disabled (and three points lower - disabled).
(After sleep box in recovery mode and very high heated!!! Probably in recovery mode does not work cooler fan!!!)
In bios advanced - miscellaneous configuration - os selection - win 7
In bios - advanced - ISCT support - enabled
ISCT notification control - enabled
ISCT WLAN power control - enabled
ISCT WWAN power control - enabled
ISCT sleep duration...- duration in second
ISCT RF kill switch type - hardware
ISCT RTC timer support - disabled
these settings LAN operating normally.
I got these settings but I'm sure not all of them are important for LAN work.
Drivers for ISCT. - https://downloadcenter.intel.com/download/23109
Important - on windose 8.1 these settings do not affect it - LAN does not work good...Last edited by deathwalker9; 09 December 2015, 06:14.
Hi, I have a question about miniDP (miniDP to DVI-D adapter).
I am trying to establish a dual-screen setup under Windows 10 x64.
1st display - Benq W1070 projector (1080p) connected to HDMI - works fine
2nd display - Samsung T260 monitor (1920x1200) connected through a miniDP to DVI-D adapter - no image
Samsung T260 monitor has also HDMI and VGA connectors, but HDMI is already occupied (has an Android box connected).
If I connect HDMI output of BJ19 to HDMI input of T260, everything is fine, but
When I try to connect miniDP output of BJ19 to DVI input of T260 (or another monitor 1600x900), the screen is blank.
Tried disconnecting all other video cables from BJ19 and T260, leaving only miniDP to DVI connection, no effect.
I have used two different adaptors with no luck:
Adapter 1
Adapter 2
Any suggestions on tested Mini Displayport to DVI adapter, that 100% works?
Can anyone share experience with Mini Displayport? Does it work at all? Any configuration you tried? Intel HD graphics is tricky with multiple outputs...Last edited by Sunam; 23 December 2015, 11:24.
I just bought one of these and am waiting for it to arrive. I have a couple of questions in case anyone knows:
1. Should I, or should I not update the BIOS? I read several complaints from people about the new BIOS having adverse effects.
2. Does this use SATA2 or SATA 3? I don't know what hard drive to buy... would it take a 1TB drive?
There are currently 1842 users online. 0 members and 1842 guests.
