It has worked fine with the stock ROM since purchase about a year ago.
The other day, on startup it just started boot looping.
Tried clearing the cache - no change.
Did factory reset and it booted up.
I figured I'd try something new since I had to reset the whole thing anyway.
I found this thread/rom and it installed pretty much without a hitch (except for the screen resolution issue in TWRP)
I only set up Netflix and KODI and it all seemed to work fine.
The next day on startup it just started boot-looping.
Tried factory-reset in TWRP (tricky with the screen resolution issue when you can't get into the ROM to set it back to 720p.. is there a way to make TWRP always 720p?) ...Didn't work
Re-flashed superceleron 1.4b... seemed fine.
Installed Netflix and KODI
everything worked for about a week.
Now it's boot-looping again.
Any suggestions?
Some sort of memory corruption? Hardware?
