Changelog 1.4b:
- Added back gapps (tested and working fine, so no more need to add any gapps...)
- Added back TWRP 2.8.7.0 recovery (If you have a scrambled screen on the TWRP go back to the system and change the resolution back to 720p and it should work just fine)
- Updated Kodi to 15.2 final with updated librtmp
Changelog 1.4:
- Removed twrp recovery due to some people having problems with it, you can download it from this forum and flash it yourself.(theres a fix read the posts in this same topic)
- Fixed Wifi on MK808b and MXQ s85 with the AP6212 chip (thks for all testers
- Removed google apps, use the "Mini Gapps" on this same thread no another one....
- Youtube fixed (in gapps pack)
- A lot beter memory management and free memory (very nice for kodi)
- And other small bits...
Changelog 1.1:
- The AP6210/AP6212 Rom is based on the 111k4.
- The RT8723 Rom is based on the 128K3.
- With the same kernel used on kszaq openelec(thks) see here for fixes = https://github.com/kszaq/linux-amlog...er_new_amports + my custom config...
- Both rooted (thks Mafarricos for the root on the EC-MK808b)
- Made some network tweaks some cosmetic tweaks and some more drivers build on the kernel.
- Wireless Xbox360 adapter added ( original and Chinese one )
- Kodi 15 + latest librtmp ( test mediacodec works great on videos not not so great on video + menus :P ) + adjust display refresh rate working just fine (Dynamic Refresh Rate) + temp...
- Cpu temp monitor script for remote ssh, in the bash write "cpu_temp" and voila to kill it ctrl+c
- TWRP 2.8.7.0 by adbul(thks)
- Some more tweaks i cant remember...
- People with the bootloader from kszaq, no need to worry because it wont write a new one... you can still have the dual boot
Bugs:
- No power off... it restarts the box/stick if you do so...(kernel bug)
- Suspend works but cant resume it...
- Xbox360 Dpad works but theres a problem if you press long time to the left it brings the power menu.. ONLY ON WIRELESS, cable is OK Fix here (http://freaktab.com/forum/tv-player-...triggers-power)
- EC-MK808B usb otg port disables if wifi is disabled (kernel bug)
First install instructions:
- * Install it by custom recovey (cwm or twrp) or the original update app on the stock rom!
- * Install by update app on the custom/stock roms....
YouTube Channel:
- Here is my youtube channel you can see it in action well +/- small videos...
- http://bit.ly/superceleron
Want to buy me a beer?
Downloads 1.4b:
- MXQ S85: http://www.mediafire.com/download/g4...leron_1.4B.zip
- MD5: F609EDAE0C639677C1D03429CA95D032
- MK808B plus: http://www.mediafire.com/download/m2...210_AP6212.zip
- MD5: C0D1C8FCB216ABFBD8E5F11D521BB022
- EC-MK808B Plus(clone): http://www.mediafire.com/download/cd...4B_RTL8723.zip
- MD5: FF16C4EF194E75E726DD1C899CC02328
USE AT YOUR OWN RISK...
Enjoy!
