[ROM] Superceleron 1.4B, MK808B Plus AP6210/6212 and Clone RT8723 and MXQ S85.
    superceleron - Revenge of the Clones -
    After flashing 3 or more boxes with the supercelron firmware I cannot go back to original.
    I'm trying to re flash / install via update package, the original firmware, and getting, this is not a m202 device, etc ...
    Since it beyond my capabilities, is it possible to re pack the original firmware so I can install it via TWRP zip.
    Original Clone of Clone firmware (Clone II)
    Cheers
      And what is the problem of those clones?
      Inside that RAR theres m202-ota-20150601.zip use that one to flash in TWRP...
        Apologies, I hijacked your tread too much, ....
        I`m Trying to flash back the original firmware.
        the boxes flashed with superceleron give error when trying to flash back original firmware ...
        ... This package is for "m202" devices; this is a "K200"
Name:	k200 Device.jpg
          Im uploading a modified m202 rom with that check removed... give a few minutes
          Edit: amlogic-s805-mk808b-ota-s1.5-20150601-MOD.rar
            Roms 1.3 Beta available on the 1º post
            Now with support for MXQ S85
            New Kernel Build. and other bits and pieces...
            Many thanks for your work and for include the MXQ S85 in your builds.
            Now I,m on OpenELEC for the support of the USB TV TDT sticks to use TVHEADEND addon in Kodi.
            I didn´t test in your rom but, with the kernel of OpenELEC, do you think that it would work the OpenELEC´s TV hardware support?
              Same kernel different config... maybe yes, maybe no...
                In AP6212, it follows without working the wifi (it does not have mac). It is rare.
                  Well that is weird, i dont have the AP6212 but like i sayd this rom is 100%(minus some tweaks) the stock 111k4 with AP6212 support...( i have 2 testers with that chip and it work just fine )
                  But i will check to see if i miss something...
                    I am going to say to him that it should return to try, because this is very rare.
                    It is that I do not have the AP6212 either, but towards the test I itself.
                      yes really very rare that... something it not rigth on that Tvstick.
                      I checked again everything.. and nothing different that affects that... so dunno...
                      Sorry...
                        Hi superceleron, I'd like to flash this build to my MXQ (bought from Gearbest). The box currently is running stock rom from NAND and OpenElec from SD.
                        My question is, can I just load this build without changing the current dual-booting? Or I have to wipe everything and install all of them from scratch?
                          Yes you can have the same dual boot, my rom don't flash the bootloader(that is what give you the dualboot).. but you loose everything on the NAND...
                            There has happened to another user the failure previously commented with the wifi (I try 3 times flashear the rom but it was continuing without working). But to flasheado this file and to worked.
                            I have been observing the files they are the same that the rom, for what I can think that the problem this one in the kernel. I hope that it helps you in your work.
                              hmm yes most be something on the kernel, i will check it...
                                There is some command or way to know the wifi without opening the mk? To insure ourselves that it is this wifi.
