[ROM] Superceleron 1.4B, MK808B Plus AP6210/6212 and Clone RT8723 and MXQ S85.
    Originally posted by bricoman View Post
    Hi superceleron
    I have a mxq s85 fw 111k4
    With your rom 1.3 i have ethernet but i haven't wifi.
    With your experimental boot3, i have wifi, but i lost ethernet; with boot 4 the same as boot 3, but with some screen flash.
    Best regards and good job
    Ok thks im going to make boot5
      Here, test this one.. lets hope is the last one..
      Boot5: https://mega.nz/#!NlphDCxT!54NAhNdOp...S8VcA-QH-wtfDo
        They say that the wifi works better
          can they test the boot 5?
            superceleron, here with mxq s85 fw 111k4, tested with boot5 and now ethernet and wifi ok, and tethering ok.
            You are the man.
              You are the man.
              Only waiting for the feedback from mega-samu
              And this one should be on 1.4
              Thks for testing and reporting
                The wifi continues working and says that the rom goes better.
                Certainly, they have brought theirs that the TWRP does not see correctly in my TV. Also it happens to the user that test the kernel. I leave a photo of the problem..
                Sorry my english. jeje
                  Android settings - hdmi output mode change 1080 to 720
                    Damm, i have another one (Portuguese) that have the same problem with the TWRP...
                    On my new 1.4 the roms they going to be different.. no more flash of recovery to avoid that problem(users choice i leave the link to the TWRP thread) and there going to be GAPPS because i removed google "thing's"(Dont worry i will give the GAPPS to flash) and a new update apk (upgrade.apk) that does the flash without user intervention
                    Beter memory management and free memory, fixed youtube(on GAPPS update)
                    Wife fixed of course on the AP6212
                    This took me a lot of time... 7gb of tries....
                    I will make a video tomorrow
                      I had the same problem with this rom. lost 24 hours to find the solution.
                      Download USB_Burning_Tool
                      Rom MK808B Plus_110k4_20150330 - 111- 114
                        What problem?
                        The recovery? that is not my rom problem... but is fixed on 1.4 simple don't flash it is user choice now... download from here and flash it yourself....
                        And the wifi problem is fixed in 1.4...
                        If you don´t like it, simple don't use it... and this is not the thread for you to you talk of others roms...
                        And you didn't need to loose 24h... if you simple come here and ask i give you the solution...
                        @All other video of 1.4 is on my youtube channel...
                          If you don't like it, simply do not use it ... thank you I do not intend to use it ..
                            For people as you, the people stop doing roms.
                              Thanks superceleron, I've seen your video with the v 1.4 and I'd remove the beta in the name
                                For as you people, the Roma people stop doing?. I think I have the right to say what I think is the Roma. I have 2 mk808bplus finless 1.1., 1 b mk808 finless. 1 minix neo-8 pm finless. 1 Teclast X98 Air 3G dual Intel OS. Roma 5.2 of mirek 190. mk808bplus gearbest.com third of it is the only one I have them problems. no wifi
                                I wanted to try this rom. and that's all .....
