[ROM] Superceleron 1.4B, MK808B Plus AP6210/6212 and Clone RT8723 and MXQ S85.
    Originally posted by Johnoo View Post
    Ok ... seems I have another clone, ... anyway...
    Superceleron, I prefer your rom, to use on these boxes,
    is there anyway I can add support for the Air mouse Keyboard.
    hmm a clone of a clone lol damm
    Ok upload somewhere the system and boot(kernel) and i will check it.
    Or if you have a link to the rom thats even beter
      Damm indeed , will be the first and last time I buy from this seller.
      TWRP used https://mega.nz/#!C9dXmZbA!_Bc2wMa_i..._yxwevS5zR8IOU
      boot https://mega.nz/#!ap1SRJTb!G9gQSdsCh...yuuqt56om8Qh60
      Im in the process of getting firmware from seller .
      System upload in progress ....
        System https://mega.nz/#!HxUhUQaK!sGqK4WqXi...KOgs3adpk7cqKA
        I removed apps and fonts, for quicker upload.
        Hopefully I`ll have link for full firmware soon.
        Thanks SuperCeleron for looking in.
          Ok can you test this boot?
          Flash it in TWRP an see if it work.
            boot-test.zip
            Just tried the boot zip, on two boxes, still the same, Left and Right mouse button only.
              that is really weird... what is make and model of your Air mouse Keyboard?
                I tried 3 types TSM01, Minix A2 and T2. All do the same, Left and Right button only ... no home button, keyboard etc ...
                This is very unusual to say the least
                I wonder if its something to do with board SOC.
                  Maybe is board soc dunno, something is not ok....
                  I checked the system and nothing new there... so
                  Im going to make another kernel from other fork, for you to test it.
                  If with that still dont work i give up m8...
                    Thanks, you have been more than generous with you time, ....
                    Just for kicks ...
                    I flashed the original stock 128k3 firmware, and the Air mouse/keyboard all work fine.
                      Just for kicks ...
                      Hmm ok, mine is based on that one... i mean all of it is that one.. so can only be kernel... i think!
                      Btw did you connect to the usb port or the OTG port?
                      EDIT: boot-test2.zip
                        Yes for original stock 128k3 firmware used "USB_Burn_tool" via OTG port
                        boot-test2 same only Left and Right mouse buttons working, ....
                        One last thing, which TWRP version you recommend. You have a link.
                        Superceleron, really don't what to take more of you time.
                        Many thanks.
                          Many thanks.
                          TWRP 2.8.7.0...
                          And i mean the air mouse and keyb... have a adapter to connect to the usb port on the device, on what port did you connect it?
                            TWRP 2.8.7.0...
                            tried both ports
                              tried both ports
                              Ok, well i'm out of ideas... sorry.
                                Roms 1.3 Beta available on the 1º post
                                Now with support for MXQ S85
                                New Kernel Build. and other bits and pieces...
