Original recovery is very picky about the sd format... that is why i recommend using a usd pen formated as fat32.
[ROM] Superceleron 1.4B, MK808B Plus AP6210/6212 and Clone RT8723 and MXQ S85.
Great ROM superceleron. Thanks for your hard work mate.
I had a problem with wireless on my stick after flashing your rom it was operational but wireless speed was constantly dropping.
The problem was the old twrp recovery I had randomly downloaded probably had been made for an older model.
I found a newer cmw recovery which flashed the ROM perfectly. So if u have problems with your flash don't give up! Try another recovery!
Also it is very picky with how the sdcard is formatted I had great success with using the windows app "HP USB disk format tool"
My mk808b plus kodi and I salute you. Killer combination
superceleron
What kitchen you used to modify 111k4? I am a developer and I can build a rom but I never used a kitchen to modify a one. So if you would be kind and guid me to the kitchen you used and what to read to start.
https://github.com/dsixda/Android-Kitchen still works, and amlogic CustomizationTool but must of my work was on the kernel side
Originally posted by envagyok View PostSorry, but i dont see it
You dont need to reflash my gapps again, since you already did it!
* If the Gapps don't show after install, go to http://opengapps.org/ choose "ARM" "4.4" and "pico" download ans install it(flash it), and it should work just fine after that.
Don't work..
When i install, then after restart isn't start recovery.. After restart immediately start android, no recovery.
I had original recovery,I tried the toothpick method booting to recovery, but not worked
Yes it work's.
Download this http://freaktab.com/forum/tv-player-...mlogic-devices the one for the mk...
Rename the img file to recovery.img, put in a sd card formated as fat32 put also the zip and use the toothpick method or with the card on the device reboot to recovery from the APP in the OS.
There are currently 1490 users online. 1 members and 1489 guests.
