[ROM] Superceleron 1.4B, MK808B Plus AP6210/6212 and Clone RT8723 and MXQ S85.
    I was trying an RD9700 , will get an asix , tks.
      Originally posted by envagyok View Post
      I have problems with install gapps
      With update software i select local update, select mini gapps for supercceleron 1.4, and install... My MXQ restart, make something, but no gapps.
      I tried with microsd card, and with usb pendrive too...
      What make i wrong?
      superceleron sorry... here exact the same... Gapps installation seems to go fine, with both method, but nothing changes on the rom, at reboot android updated 55 app...where he put them??
      It may be the recovery? (i'm still on stock) I've tried to install many versions of TWRP, from the relative thread, but I cant find the one for my device: EC-MK808b+ (S805 + rtl8723bs) On the terminal I see root@m201 obviously I'm using "EC-MK808B Plus(clone) 1.4"
      (I do not know what's the stock rom, but I can ask to seller)
      Please can you indicate the correct recovery version and install procedure? OK if you have some ROM remaining work ready for my case...
      Many thanks
      Gloria
      edit:
      I moved on... but... OK i've found this one and tried, surprise it boot and is also the last, so I tried to reflash gapps...nothing...
      I just can reinstall the rom by TWRP, i'll give a try
        First install instructions
        * Install it by custom recovey (cwm or twrp)
        * Install by update app on the custom/stock roms....
        * If the Gapps don't show after install, go to http://opengapps.org/ choose "ARM" "4.4" and "pico" download ans install it(flash it), and it should work just fine after that.
          Yes thanks, installation by twrp of both rom anf gapps went well but play store say me that device is incompatible also with deropbox... It's an odyssey
            Next week i build a 1.4a with gapps on it! now i cant holidays.......
              Maybe I just have no luck with this rom, date and time return in 1970 after power off/reboot (tried enabling and not the automatic sync), this impact on many app...in addition to google play services/store. Reflash reflash and reflash... Ther's some other rom suitable for the wifi adapter rtl8723bs?
                No RTC m8... no other rom going to help you on that....
                  SuperCeleron,
                  Since switching to Kodi 15 cannot watch Live Uk Tv anymore, its all we watch mostly.
                  Picture pauses and resumes without audio+Jittery picture, and does not recover, have to stop and start.
                  Video shows what happens
                  https://www.youtube.com/watch?v=f7Yc...ature=youtu.be
                  Is it possible to patch the previous 14.2 librtmp.so, to test, recompiling Kodi 15 with Kodi 14 librtmp does not work.
                  (knew it wasn't going to work but I`ll try anything).
                  Connected with WiFi using this simple setup.
                  Kodi Logs, (included are Kodi 15, and 14.2 for reference).
                  Logs.zip
                    Superceleron , please, for our Italian friends , you can add Italian keyboard ?
                      Originally posted by Johnoo View Post
                      SuperCeleron,
                      Yes i know of that problem, sadly i cant do much about it, they made changes to the internal structure of how the lib works.... so it does that on some chip/rom combination
                      Did you try the latest one that i compiled(22-12-2015)? theres new fixes!
                      Is on my mediafire account!
                      Sorry m8 no more rom from me for this devices if i rls another is only to add gapps..
                      Search the playstore, you should find what you want
                        Yes much worse on Amlogic, but also sometimes happens on my Rk3188 CS918.
                        Just tried latest, no change, does the same pause then resumes without audio etc..
                        tks SC just the same, maybe future fixes will help resolve the issue.
                          just tried to flash this rom with twrp 2.8.1.0 - finless ...
                          Wiped cache, system and data befre, made a factory right after the wipe.
                          Now the following log shows two or three errors:
                          Code:
                          Creating symbolic links
                          symlink: some symlinc failed
                          [COLOR=#FF0000]E: Error executing updater binary in zip 'external_SD/ROm.zip'[/COLOR]
                          Error flashing zip 'external_SD/Rom.zip'
                          Updating partition Details ...
                          [COLOR=#FF0000]E: Unable to stat '/data/lost+found'[/COLOR]
                          ... done
                          What am I doing wrong?
                          Edit: Well now it is not booting anymore ... Not even in the recovery... Is there still a way to get it running again?
                            grab a stock img and flash it with usb burning tools in windows, or put a recovery.img and the rom zip on a fat32 sdcard and boot to recovery by using the reset button...
                              using the reset button won't work since i had a different recovery installed?
                              downloading a stock image right now, this is one, right?
                              http://blog.geekbuying.com/index.php...date-20151215/
                              Do you know why the flashing was unsuccessful?
                              EDIT: SDCard way works, havn't tried the tool. It is flashing right now, thanks!
                                Hy superceleron, can you mod your rom's to playback hd audio passthrough with VidOn xbmc?
                                Maybe implement unrestricted VidOn xbmc from Tronsmart rom?
                                You can try VidOn xbmc s805 chipset can hd audio passthrough with it.
                                VidOn XBMC (Kodi) is an all-in-one Android player which can play DVD, Blu-ray and video, and supports Blu-ray menu navigation, hardware decoding, and SPDIF passthrough and HDMI Passthrough.
