[ROM] Superceleron 1.4B, MK808B Plus AP6210/6212 and Clone RT8723 and MXQ S85.
Originally posted by bajann View PostWith update youtube apk video max 360p they change something
#There is any way to see youtube at 1080p? xposed module doesn't work :/
P.s.also fixing lowmemorykiller youtube background,xposed module,doesn't work..sob
#the rom include dolby digital library?
Hello! superceleron i accidentaly flashed your rom for original mk808b plus but i have rtl8723. It flashed ok and boots to it normal, but i cant enter recovery mode from reboot apk to flash the EC. It just reboots and loads the rom. What can i do now? Thanks!
Originally posted by superceleron View Postyoutube 1080 nop, never got to work!
The lib, i think yes.. but not 100% sure... i cant remember lol!
-1080p youtube: youtube for google tv
-add also in first page that for resume the device from suspend mode it's needed a program like volume power button
Other tips are coming..i have also compared 112k4 rom (really few things updated).
-The only thing that i don't understand is when your mali450 driver was builded:/
The latest 112k4 rom include a different driver from yours(no support for egl v1) and is dated 28/aug/2015
1º yes i think it was that the i added to the rom, but cant remember (2 many rom build 2 many stuff around maybe i added the wrong one lol)
2º yes i need to add to the 1º page that solution
3º mali driver, https://github.com/kszaq/linux-amlogic still based on the 01/2015 or 02/2015 kernel! And yes the 112k4 the mali driver is from a more recent kernel (04/2015) and lost support egl v1,
that is why i opted to use the old one, more stable a works a lot better on the videos(kodi) and a lot of private(see commits log) fixes!
Originally posted by superceleron View Postformat the sdcard as fat32 and put the recovery.img(extract it from the zip) and the zip on the card, and put toothpick on the reset bottom and connect the power, stop pressing when you see the logo!
â€Thanks for the ROM. Just flashed it on my mk808b+ clone. For some reason most of the apps that worked on the original ROM are not compatable with this one:
Google photos, CPU-Z, HWmonitorPro, Nova launcher, Drop box ... What's wrong?
Also, an MKV file I have on an SD card will not play smoothly, even though it does play on an older stick (mk808). The device does not support the DTS soundtrack. Any advice?‹
There are currently 5842 users online. 4 members and 5838 guests.
