[ROM] Superceleron 1.4B, MK808B Plus AP6210/6212 and Clone RT8723 and MXQ S85.
    Kazar i don't think is connected but, so dunno about the driver, check the sources!
    Stimmenhotel like prahjister said, watch out if you do a good solder(that thing is really tiny) and the clones uses the realtek chip
    About the cable, i never tried so i cant tell(it and miss?) but if you have a old laptop for parts the one that comes with it are good!
      Well, I will see when I open it for placing the heatsinks.
      Parts from old Laptops is a very nice idea, I will check what I can find.
        SpiritFM1,not the latest version, recognize broadcom module but report error: power supply. Another version wrote maybe needed driver in the kernel. So any idea of where get a tablet with this kind of soc to try? I belive some chinese device used..just a test
          on last version 1.4b i have bootloop after enabling ART
            That "problem" was already mentioned somewhere ... Just don't do it? xD
            A reflash should help
              Ok, I'll try it. Another question is how to save Display Position, after restart position reset to defaults.
                You mean the overscan?
                Should be saved automatically...
                No problems for me.
                But if you want to use 3D with kodi (and maybe other apps), you should set it to 100%, else you have serious ghosting. Only change the zoom with the TV.
                  Well now ...
                  Today I decided to open my stick again.
                  The Idea was to plan the heatsinks for later manufacturing.
                  And placing the wifi antenna to the outside ... This is why I posting this...
                  As you can see the cable for the antenna goes from the board to the shell.
                  There is a sponge, coated with metal mesh ... and the mesh would press on the mesh on the board...
                  Dows this all belong to the antenna? Someone knows this?
                  Or is the antenna under the sticker?
                    The sponge is... only a sponge nothing else and the antenna is the sticker
                      ASking, because below the sponge is a metal surface.
                      And according to my continuity tester, there is a connection between the ant/gnd pins and the sponge.
                      I don't think ot makes much sense to install some shielding and put it on the same wire as the antenna xD
                      Anyway...
                      I think I have to wait for some lower profile heatsinks... 3cm tall is to much
                      Edit:
                      If there were no down traffic for the reference speed test ... (Good precondition... "IF" ...), I had about 7 Mbit/s downstream with my stick.
                      Now I have doubled it to 12Mbit/s!!! That is nearly as much as I pay for.
                      Another question...
                      I checked the kernel tool lately to see i the stick is throttling it speed.
                      If it runs at 1,2Ghz instead of 1,5Ghz even if I choose performance... It is throttling, isn't it? (There is not even one precent for 1,5Ghz)
                        Yes that metal surface is part of the sticker!
                        Mine default speed(fiber 200mbits) is with the stock rom around if i remember correctly 8/10mbits, modded the rom around 20/26mbits antenna outside 29/31mbits.
                        And yes it says 1.2ghz because it starts throttling at 70ºc to 1.2 at 80ºc to 500mhz if i remember correctly, and the normal without the mod ir always around 70ºc!
                        Check the kodi supplied to see the temp, or open terminal emulator and type "cputemp" and you should get a loop script checking the temp every 3 secs, that is why i have put that script to the ppl check they temp by ssh, telnet remotely!
                          Anyone know if there is a fix for amazon prime video crashing upon trying to play anything? I dont want to have to buy a fire tv stick :'(
                            If i try to install to my MK808Bplus, from TWRP 2.8.7.0 (after [ROM] KI Valkostur 20160202), and after clear all data, I get this message in recovery:
                            E:Error executing updater binary in zip 'external_sd/MK808B_PLUS_SuperCelereon1.4B.zip'
                            Error flashing zip
                            What is wrong?
                            (Maybe after Reboot to system, and get back to recovery, it is installed. Why i have make a reboot, after wipe?)
                              weird never happen to me so dunno m8, Chinese stuff sometimes does that
                                OK
                                I can install it but now i unable to turn on the wifi.
                                And i have no MAC address (Unavailable)
                                This ROM is compatible with AP6330/6210/6181 and 6212?
                                How can i get back my wifi?
