[ROM] Superceleron 1.4B, MK808B Plus AP6210/6212 and Clone RT8723 and MXQ S85.
Originally posted by prahjister View PostCan you compile a kernel module for rtl8188cus? I have usb wireless I am trying to get working
So not much time!
Originally posted by braguzz View PostIf I enable upnp in kodi and then I add a upnp file library it works. if I restart 808b, file library doesnt work until I restart upnp service.
It is a bug or I miss something?
I never tryied the upnp so i cant tell, if i have time i will check on mine this weekend (i have it stashed.. because is dying...way to much abuse)
superceleron any hope for a new version 1.5? Your rom is pretty stable but i'd like to know if is possible to upgrade it with latest firmware 112k4 (august): where shutdown button works and without under cunstrution logo + google tv launcher(i mean by default)? Does OC work with your rom? Because i have set governor performance and min-max1,5ghz but frequency still switch between 96-1,5ghz.
I have installed gapps pico version but aosp keyboard is not working anymore and i have fixed it installing google keyboard from the play market
i have ran into quite a pickle!
i flashed stock 111k4 using burning tools then flashed this rom using cwm. it completed and said reboot etc but the menu to reboot didnt come back up, i waited for a bit and still no menu came up, back buttons werent working etc so i pulled power and when i turned it back on it just sat on a blank screen giving me nothing! :<
i tried resetting device and going back into recovery but it wouldnt work, ive tried to use burning tools to go back to stock but my device no longer shows up. ive tried the newer version of the burning tools and still no luck :<
any help would be greatly appreciated!!!
i bought this from gearbest a month ago so has new wifi drivers
thanks!Last edited by d0tcould; 20 December 2015, 00:07.
I only used burning tools for the 111k4 stock rom and then tried flashing your rom via sd card in cwm. I had flashed cm12 and finless in the past which flashed fine but wifi drivers weren't there so I gave your rom a go.
Unfortunately now I can't do anything. Can't get burning tools to detect my device and can't get into recovery
hooo it wont detect it, some of your other flash gone wrong...
The only way that i know, and is a 50/50 chance of working is this - http://freaktab.com/forum/tv-player-...finless-method
Read all 3 pages of it!
There are currently 4452 users online. 1 members and 4451 guests.
