[ROM] Superceleron 1.4B, MK808B Plus AP6210/6212 and Clone RT8723 and MXQ S85.
    Hello
    Superceleron, your ROM it's fantastic, it´s very beautiful, very fast, i like so much,...for me the best.
    Unfortunely i don't have WI-FI with this ROM, I install very easy but no wi-fi.
    I've teste the rom clone and original, same result on both.
    My mk808b plus it's the same on this link:
    Thank for anything you can do for me and people have the same Android.
      rtl8723bs? my clone one should work...
      i need the rom from that one to see what is the difference.
        Superceleron, as I said earlier, very happy with the rom, but discovered that the power button on the display bar only reboots but will not shut off the device, am I doing something wrong?
          it's a bug, i cant fix it :/
            What if I install an apk from google store like reboot?
              Wont work is a kernel + bootloader problem :/
                Thanks , regarless, great rom.
                  thks
                    Hello superceleron.
                    Lile i said before fantastic job.
                    I don't know what i've done before, but today i try again install your rom (ec-mk808b plus) and now WI-FI work.
                    THANK YOU very much for your fantastic job.
                    p.s. power button on the display bar only reboots...that's true
                      Originally posted by batistabomb View Post
                      Hello superceleron.
                      glad it worked
                      Ainda bem que funcionou
                        I have install the ROM.
                        So far so good!
                        Thanks for the ROM!
                        One question:
                        Is not rooted. I miss something? How to root the ROM?
                          So far so good!
                          Thanks for the ROM!
                          One question:
                          This ROM is rooted.
                            like organicminds said the rom is rooted!
                              finally the problem was the recovery.
                              Switching to TWRP from here, http://freaktab.com/forum/tv-player-...us-cwm-or-twrp, post #13, after the installation the root was OK.
                              I like this rom!!
                                Is there any TWRP special version for clones? Some people trying to install the firmware and with the original recovery.img doesn´t work
