[ROM] Superceleron 1.4B, MK808B Plus AP6210/6212 and Clone RT8723 and MXQ S85.
    It seems that the last twrp doesn't work with the clone or at least with some of them. Where can I download the cwm to try it?
      I only know the wetek gift one..
        or try a older one, https://mega.nz/#!o5ZSWQTC!ylKn17F5w..._wcyOJyda1gS50
          Yes it work's.
          Download this http://freaktab.com/forum/tv-player-...mlogic-devices the one for the mk...
          Rename the img file to recovery.img, put in a sd card formated as fat32 put also the zip and use the toothpick method or with the card on the device reboot to recovery from the APP in the OS.
          Thanks, already working
            nice
              From banggood they have sended a new firmware version for the clone
              At least, the date is not the same that you posted in #144. Can you see if it is the same that you have or they've changed something?
              Thank you
                well i dont see anything new, but without testing is hard to tell ... but a lot of crap and no root..
                  Anyone's opinion which is best, mk808b plus or mxq using this rom? I've heard the mk808b plus has wifi problems though.
                    well wifi is little beter on the mxq and have eth, but i never tried a mxq...
                      Thanks, I'm going to try your rom
                        Hello! I in the end am also interested in flashing an original MXQ S85 Beelink ( with the red stripe and "," and on/off square button in the centre). Will wait for Valden findings. But I have also another question for Mr. Superceleron: can I flash only the System part avoiding formatting all data ? I have seen in the flash procedure that everything is erased, so something different should be done to avoid losing all data. But as first if .aml file is the same as stock ROM (meaning, if I not wrong that you have not modified partitions ) this should be a first place to start from.
                        Thanks again for Your marvellous work!
                        Regards
                        Alessandro
                          Must add another question for Superceleron: with other custom firmware I had been able to make my USB to Ethernet adapter work, but this time no dice, maybe I used a wrong USB hub to connect the adapter!
                            I think, I had the same issue. See the link below.
                              vn800art
                              You need to edit the zip and go to "META-INF\com\google\android" and edit "updater-script" remove
                              Code:
                              ui_print("Formatting /Data");
                              format("ext4", "EMMC", "/dev/block/data", "0", "/data");
                              But i wont promise after that it will work ok...
                              The eth usb problem check the link of mowgli i already give a answer to that
                                Thanks Mowgli and SuperCeleron ! Will try and report back. As I read it is clear that this works on MXQ S85, too !
