[ROM] Superceleron 1.4B, MK808B Plus AP6210/6212 and Clone RT8723 and MXQ S85.
Originally posted by bricoman View Postsuperceleron, sorry i´m newbie, you have mini gapps - Whats this ? Is instaled before or after rom 1.4 ? Is possible give some instructions ?
playstore, youtube ....
And is after the rom and not beforeand only if you need it... i dint need but that is me, your choice
Google apps, and what is needed to run it
When i try this i give you feedback.
With 1,3 i´m very happy, i split from openelec to your rom, because it´s very quick and kodi works superbly.
Thanks for your kindness
edit .. UPDATE ...
Fixed in 1.4
Those no getting WiFi, using TWRP, try this older version.
Thanks Superceleron!!!
Pros
-CEC Control does not stop working after 30 sec. like all other Android roms that exist for MK808B plus !!!!
-Fastest Android for MK808B plus.
-Lowest RAM usage
Cons
-None
Usage:
-I have setup ROM Collection Browser in Kodi using the latest Retroarch version and it is running NES roms perfectly. I have my PS4 controller paired and setup in Retroarch. It goes between Kodi and emulators very quickly
-This version of Kodi is just as fast as Openelec
-The fixed CEC control is the best!
Thanks again!!!
My Stick : http://www.amazon.com/Andoer-MK808B-.../dp/B00PU52CGA
Originally posted by mega-samu View PostIt gives good results brilliantly, the last version.
A question that wanted to do you: did kernel may port of superceleron to cyanogenmod 12? Since your work seems to me to be impressive.
Yes is possible but i need to take a rest from this, for a bit im tired and the device is getting damaged (mini usb power socket) from all the connect disconnect... since May that i'm doing roms for this device some private and some for Portuguese people!!!
After i finish my other project i will check that or i will wait for 3.18 kernel from amlogic....
Originally posted by kokonuts View PostI hope you remembered to do something about ADB problem in 1.4 release. Did you?
Thanks,
But like that you can work with it just fine
Originally posted by sammaz View PostThanks Superceleron!!!
Pros
-Lowest RAM usage
Cons
-None
Originally posted by menthorul View Posthi, can i install on my mk 809iii b with rtl 8723 wifi ?
Originally posted by bricoman View Postsuperceleron ROM 1.4 is great
full compatible with mxq s85 with fw 111k4
Very fast
Very good job
Thanks , you make my box work in android very fast, not like the junkie stock rom.
There are currently 3070 users online. 0 members and 3070 guests.
